Old 05-18-2010, 02:02 PM   #1
72gmcshorty
72gmcshorty's Avatar
Airbag setup help needed...
All right, i've pieced together a setup that i hope will work for my blazer. I have 2 - 4 port 5 gallon tanks, and 8 valves. I was looking at the suicide doors page for setup but they don't have one for 2 tanks. There pic also shows a tank pressure gauge. Is a tank gauge necessary? If so, does it matter which tank i hook it up to? My pic shows how i hope to run it. The green would be the compressor. How could i hook up the tank pressure and pressure switch? And, would i need two check valves?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-18-2010, 02:04 PM   #2
72gmcshorty
Re: Airbag setup help needed...
or like this?
1992 Gmc 2wd
Old 05-18-2010, 03:37 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
just like mine..works fine but your compressor is on borrowed time because it takes so long to fill both tanks it wont last long...I fill at the house now because mine pooped out...you should get 2 or mabe 3 dump/fills..one tank switch will work for both
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-18-2010, 06:26 PM   #4
72gmcshorty
what's the max size tank recommended to be used with one air zenith compressor?
1992 Gmc 2wd
Old 05-18-2010, 06:34 PM   #5
Hottrucks
Hottrucks's Avatar
I think a 3 gallon...alot of guys are running dual via air 580's I think but who has $500 for them
Old 05-18-2010, 06:51 PM   #6
hotrodhomi
hotrodhomi's Avatar
My blazer is set up like the first picture. I'm running a york to fill both tanks.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-19-2010, 06:41 PM   #7
72gmcshorty
i found a couple of 2.5 gallon tanks local here. I probably get those instead of the 2 -5 gallons ones. What size pressure switch is normally run?
1992 Gmc 2wd
Old 05-19-2010, 06:55 PM   #8
Hottrucks
Hottrucks's Avatar
depends on your compressor..any where from 120 to 230 lbs
I see your going to run the ZA I would check there we page
