05-18-2010, 09:26 PM | #1 |
'66 GMC Suburban reverse light lenses...
Does anyone know where I can fine a pair? One of mine is busted pretty bad.. Its the passenger side one, but I know they are both the same.
Oh... and has anyone with the 305 v-6 ever tried that Pertronix ignition or tried to do an H.E.I. swap? Im trying to find out some info on that stuff too.. Thanks |
05-18-2010, 09:36 PM | #2 |
Just here to tinker
Re: '66 GMC Suburban reverse light lenses...
Hey bud, just visit www.6066gmcguy.org and that should tell you all you need to know about the HEI swap, although I run points still and never have a problem on my V-6. Just adjust the gap during regular tune-ups and they are reliable!
As for the tail lights, I am not sure.... WELCOME ABOARD! I want a burb so bad....
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
05-18-2010, 10:05 PM | #3 |
I've seen a few on ebay from time to time... but its going to be rough.
05-18-2010, 10:29 PM | #4 |
Yeah, I love that site, its where (so far) i've gotten most of my info. Im just wondering if anyone on here has tried any of it...
Since you have a 305 i have a Q for you.. with all new tune up parts, and the holley carb swap, which worked out well..in fact when i bought my sub 8 years ago it had a holley 2bbl already on it. (i upgraded to the 500 about 4 years ago).. anyways to get back to my point.. i parked it for a bout two years and did the usual storage maint. on it, but for some reason after it warms up and gets on the road, it likes to die.. not flat out die, but like idle down until it dies. i cant figure it out because it idles fine in park, and in drive, just after i get driving it does this.. any ideas? |
05-18-2010, 10:34 PM | #5 |
Have you checked the tank sock screen, or carb filter, or external filter. sounds as if your running out of fuel...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
05-18-2010, 10:41 PM | #6 |
yeah, i just took out the tank, cleaned it out, put in a new sending unit w/sock, and replaced all my fuel filters (one in-line and one in the carb)
05-19-2010, 12:16 AM | #7 |
I think the reverse/back up lenses for the Suburban and the Step side are interchangeable. They might be a slightly different shape than the Suburbans but at about $5 a piece you can get two to match cheaply enough. Measure the diameter of your good one and contact any of the major after market dealers (LMC, Harmons, Golden State....) and see what size their step side lens is.
05-19-2010, 12:18 AM | #8 |
www.truckandcarshop.com is a good source for the Burb stuff.
05-19-2010, 12:26 AM | #9 |
I bought these from arrowhead truck parts in Glendale Az. they are not correct but fit and lookgreat. I think they are from a 67-72 trk. Hope this helps.
2-20, 2-21 whatever it takes! |
05-19-2010, 09:12 AM | #10 |
I have the GM HEI in my 1966 GMC with 305E. I am very happy with it. The HEI produces a much hotter spark than the original ignition which makes it easier to start and prevents fouling plugs. I haven't had to touch it since it was installed. The 6066gmcguy.org site has all the plans.
regards, Steve New Orleans |
05-19-2010, 09:47 AM | #11 | |
Just here to tinker
05-20-2010, 04:31 AM | #12 |
Thanks for the tip.. in fact i just noticed today that there was fluid starting to seep out of the weep-hole in the side of the fuel pump. Ill replace it asap and see what happens.
