#151 |
Re: What did you do to your truck today!
Replumbed the fuel cell... Went from -8 to -6 bulkhead...had to make a couple of aluminum washers to fill the 3/4" hole in the fuel cell.
Also started making some fuel line brackets out of aluminum flat stock. They hold 2 3/8" aluminum fuel lines from the notch back to the fuel cell. Then the ones in front of the notch will be 2 3/8" fuel lines and a 3/16" brake line. Originally saw how to build these on the HAMB forums...but someone has a write up here in the FAQ. Pics later Kinda hard to get the 3/8" holes right in center of the 2 pieces of aluminum. But they will work fine. The long bracket needs to get cut down. It was the first one...trying to get the spacing right. ![]() Last edited by 8mpg; 05-19-2010 at 04:24 PM. |
#152 |
knuckle buster..
![]() Join Date: Oct 2007
Went to the body shop to tape out the separation for the two-tone paint scheme and the colored stripe that runs between the two colors
![]() I am stoked it comes home this weekend!
_______________________________________________________________________________ Eric THIS SITE ROCKS!!! ![]() Check out my suburban on 20's with fresh paint! Click here to support the site Check out the Member Photo Gallery here StreetCruizin FAQ thread Site vendors list (scroll down to vendors in red) ![]() ![]() |
#153 |
Threw an entire demolished bathrooms worth of sheet rock, tile and concrete in the back! Love those extra leaf springs.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
#154 |
Painted Front front clip and rear fenders, busted my knuckles and the lower bolt trying to lower the rear end, toook off the old bed and removed the old rusted fenders.
[IMG] Took off the old bed, [IMG] [IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#155 |
Factory Strippers Rule!
![]() Join Date: Mar 2009
Got my blower hole cover in the mail!
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
#156 |
Cruzin
finally finished painting my wheels
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#157 |
installed new tie rods
'68 C10 LWB 6.2NA/NP833 3.73's |
#158 |
Sheetmetal Psycho
Stuffed the '71 in the garage and jacked/blocked it up. Sprayed everything with PB blaster that I think I needed to for the axle removal. Chased a wiring issue with backup lights. Keeps popping fuses.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#159 |
optomistic ah-so
This took longer than a day but I had "help" from Mother Nature
![]() Anyone who saw my truck at GotG knew I was catching up with a "parking lot" water pump change and leak...chased it through a few quickie attempts until Sunday I took everything off the front of the motor, then the rain started falling hard and drove me inside. I cleaned, prepped and spray painted everything (not show quality, just better and lighter without the crud) and suffered through primer up my sinuses ![]() No leaks finally and I identified my next project--the balancer needs to properly removed and reinstalled. Also discovered the replacement radiator I have to go in, has been a 4-row all along. Maybe I shouldn't do things to the truck anymore, I keep finding more things to do!!!
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. ![]() |
#160 |
I let my daughter take a friend of hers out in it. They made it back in one piece. whew.
![]() Dad's 1970 Chevy C10 Custom 350, auto, armstrong power windows and doorlocks "My carbon footprint is bigger than yours" ![]() ![]() |
#161 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
mINE IS GETTING THE FULL ATTENTION TODAY FROM ME AND HOPEFULLY THE NEW HARNESS WILL BE FINALLY INSTALLED.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#162 |
![]() Join Date: Oct 2009
Evacuated and charged my new A/C system with R134a. Outlet temperature was about 40F when outside temp was about 90.
1971 C10 Longbed, 350/TH350 |
#163 |
Cruzin
got me a 3/4 ton junkyard sway bar for $25
#164 |
Added a door logo!! (bling)
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 |
#165 |
Installed the new Jeep spring to lower the rear.
[IMG]
#166 | ||
"I ain't nobody, dork."
I took the laundry out of the dryer and set it on the hood...
![]() Gary
#167 |
![]() Join Date: Feb 2007
cut out floor got ready for new
#168 |
Designated Grumpy Old Man
![]() Join Date: Oct 2001
After NickP51chevy wired 98% of the complete rewiring I installed the headlight wires and installed the new dash gauges.
Thanks Nick. It wouldn't have got finished without you.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg Last edited by oldiron; 05-23-2010 at 01:53 AM. |
#169 |
Kev0519, That looks sick!! Nice work!
Today was the day my Offy intake finally went on, swapped the throttle assemble from rod to cable, ripped off the water intake and recent power steering project parts off to get them all painted and ready for re-install. Should be able to get the new gas pedal set up and fire it up on monday (Long weekend!) |
#170 |
Put in a new powdercoated axle with a new diff cover, Big brakes, and a detroit locker
#171 |
started removing the front clip. Pulling out the old tired 350 and installing a 450 hp big block next week.
#172 |
Man that looks sweet.would like to see more pic's of it.
big old burb in primer.lot of work to do. |
#173 |
What?
Replaced, regapped the spark plugs, and adjusted timing.
Replaced the glove box emblem. Piddly stuff today...
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#174 |
ok, this weekend i put all new rims on 71 gmc longhorn, put in headliner, took my tonneau cover to have an additional 7.5 inches added on (it is a longhorn) so it had to be customized. oh yeah, took it fishing too!
#175 |
![]() Join Date: Aug 2007
Got my butt handed to me trying to do a valve lash adjustment
