Old 05-20-2010, 05:01 PM   #1
bowtiecb
bowtiecb's Avatar
serpentine conv ?
i coverted to a 92 firebird serpentine set up, my quest is, what did you guys do with the a/c wires on back of the compressor, its two wires, i think its for pressure, did you just twist them together?
bowtiecb is offline   Reply With Quote
Old 05-20-2010, 08:05 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: serpentine conv ?
are you sure its not for the compressor clutch? if not how many wires do you have?
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 05-25-2010, 12:35 AM   #3
bowtiecb
bowtiecb's Avatar
total of four wires, the grn&blk that cut the compressor on, and then theres two more on back side that has a small round plug
Old 05-25-2010, 12:52 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The backside is a high pressure switch. You definately want it wired. Otherwise you will blow up your lines. Wire it in line with the low pressure switch. The low and high pressure switches are wired in series. If either is switch is activated, the compressor is shut off.
Take the hot out wire from the low pressure switch. Wire it to one side of the high pressure side. Wire the other side to the hot compressor wire. Wire the ground compressor wire to a good ground.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-26-2010, 12:01 AM   #5
bowtiecb
bowtiecb's Avatar
thanx
Old 05-26-2010, 01:23 PM   #6
54Caddy
GM Addicted
54Caddy's Avatar
i plan on also doing this swap, did the wires for the stock alternator reach to the other side and did they hook up?
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-26-2010, 09:24 PM   #7
bowtiecb
bowtiecb's Avatar
you will need 2 make or buy a plug with resistor, depending n whether you have a light or gauge. i bought the plug end from an alt. shop, and the resistor from electronic store, but if i do it again ill just by the adapter
Old 05-27-2010, 10:52 AM   #8
54Caddy
GM Addicted
54Caddy's Avatar
ok did all the existing stock wiring reach, my alternator is on passenger side and with the serp bracket from the 89 chevy that i have its on the driver side, was yours the same??
..Mac’s Garage..
IG:MacsGarage
Old 05-28-2010, 07:03 AM   #9
bowtiecb
bowtiecb's Avatar
Yes alt is on drivers side with comversion
Old 05-28-2010, 02:39 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
so the stock wires did reach to hook up the alternator??
..Mac’s Garage..
IG:MacsGarage
Old 05-28-2010, 08:55 PM   #11
bowtiecb
bowtiecb's Avatar
yes with this Amazon.com: Dorman 84731 2-Wire CS To SI... Amazon.com: Dorman 84731 2-Wire CS To SI...
