Old 05-20-2010, 06:38 PM   #1
richcz28
Frame Tabs & Body Mounts ????
I have a 1977 gmc C15 pickup long bed regular cab 2wd that I am currently restoring. I have this truck completely torn down to the frame rails currently. Some of the tabs on the frame where the body mounts to the frame are rotted. My frame is rot free. I am looking to replace these tabs as they are just riveted on. I have searched for these tabs at reproduction shops like LMC truck. I have only found tabs for the updated frame as can be seen on page 35 of the LMC truck online catalog. I beleive the years are 81-89 or something like that. So my questions are....
Can I use these LMC reproduction frame tabs? (I have read they work with the newer body mounts.)
Are there frame tabs available for a 77 someplace else in reproduction?
Thanks.
richcz28 is offline   Reply With Quote
Old 05-21-2010, 04:13 PM   #2
richcz28
Re: Frame Tabs & Body Mounts ????
bump....
anybody?
Old 05-21-2010, 06:50 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
How many do you need and which ones? I will have a spare set of cab mounts from a 74 K10 if they will do you any good.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-21-2010, 11:16 PM   #4
richcz28
I need one cab mount tab and the two radiator support tabs (I think they are called).
My drivers side cab tab is in literally new condition, but the passenger side is almost nonexistant.
The passenger side cab mount would be a great help, because I think otherwise I will need to fabricate something.
Old 05-22-2010, 12:46 AM   #5
bikes&bowties
bikes&bowties's Avatar
if his dont work I have a 77 chassis with that stuff on it... Pm me if need be
bikes&bowties is offline   Reply With Quote
Old 05-23-2010, 09:44 AM   #6
68 TT
68 TT's Avatar
The front or rear cab mount bracket? The rear ones are inboard of the frame and the front ones are outboard.
I need to keep the core support tabs on mine as this frame is going under my 67 cab and the core support tabs are also the front leaf spring mounts so they need to stay.
Old 05-23-2010, 11:11 AM   #7
richcz28
I have a 2wd so my front supports are most likely different. I am referring to the tabs outside the frame, not the mounts that go in the crossmember.
Old 05-24-2010, 11:41 AM   #8
68 TT
68 TT's Avatar
Take a picture of what you are working on so we get it right.
Old 05-24-2010, 12:40 PM   #9
richcz28
good idea. i'll take some pics this evening.
Old 05-26-2010, 09:27 PM   #10
richcz28
The forum doesn't want to let me upload my images. I can email them.
Old 05-27-2010, 10:57 AM   #11
68 TT
68 TT's Avatar
Most likely you need to resize them so they are smaller. Right click on the image and select edit. This will pull up windows photo editor so you can resize them easily.
