05-21-2010, 11:38 AM | #1 |
Loose rear window
My rear window is loose. This has been upgraded sometime ago by previous owner. Its currently a sliding rear window. I have a shim of sorts wedged in so it doesnt move back and forth. Is this a fault of weatherstripping?
Can I simply just replace this and have it fixed? Or is there more to it. |
05-21-2010, 01:04 PM | #2 |
Project collector
Re: Loose rear window
If the opening is not modified then with the rubber is worn or the aftermarket window is too small. You should be able to replace it easily. I would add a new rubber gasket to make sure it's good.
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
05-21-2010, 01:57 PM | #3 |
When you say opening are you referring to the actual window? If so, no that isnt modified.
Also when you say gasket, are you referring to the weatherstrip? Thanks, Matt |
05-21-2010, 02:52 PM | #4 |
Project collector
Yep, opening is the steel opening that GM stamped into the cab sheetmetal. The rubber weatherstripping sits into that and holds the glass/aluminum housing for sliding window.
05-21-2010, 04:29 PM | #5 |
Ok I just ordered some new weatherstripping for the backwindow.
Is it difficult to install this? Do I put the adhesive on the weatherstrip or the cab? |
05-21-2010, 05:52 PM | #6 |
did you order the rubber for a slider or was it a stock window? We sell the slider and most times it requires a rubber for sliders The ones we sell fit the OEM gaskets but not all Mfg's do.
05-21-2010, 05:54 PM | #7 |
