im having trouble finding a 71 or 72 c10 center link. are there any stores/web sites that sell them out there. I'd be lucky to find one in a junk yard around here. I have a 67 c10 that im using the 71-72 spindles for the disc brakes. was told that the steering linkage needed to be 71-72 as well?
Moderator
![]() Join Date: May 2007
Re: 71-72 center link
I think you can use your existing centerlink if you use 71/72 outer tie rod ends and 67-70 inner tie rod ends. The only thing that would prevent you from doing that is if the tie rod adjusting sleeves are different between the two, and that I do not know. One of the experts will chime in to verify that I am sure.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 05-22-2010 at 10:53 AM. |
![]() Join Date: Mar 2008
http://67-72chevytrucks.com/vboard/s...ad.php?t=13692
Read this link for the FAQ on centrelinks and tierods. If you can't find a centrelink let me know, I've got a couple 73-87 on the shelf. Good luck. |
Moderator
Bingo, that link answers your questions, and my curiosity. It looks like you need a special adjusting sleeve if you mix two different year tie rod ends.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Awsome! Very helpful. THANKS ALOT!
Restoration Virgin!
just another fyi....difference b/w 67-70 center links and 71/72 center link (holes are bigger...thus the reason for different inner and outer tie rods needed)
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
