05-22-2010, 10:42 PM | #1 |
Fun Stuff
I need a measurement, please
I am converting some pickup doors to Suburban front doors. I have the window frames, but when I got them I neglected a critical measurement.
I didn't get the measurement from the front corner to the back corner. Any help would be much appreciated!
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd Last edited by jayman68; 05-22-2010 at 10:43 PM. |
05-23-2010, 12:22 AM | #2 |
Devil's in the Details
Re: I need a measurement, please
23 3/8" on mine. That's measured in the same spot with the tape measure in the exact same position. I measured until right where the window frame starts to descend. It looks like your guesstimation was only off about 1/16" from my Suburban's door.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
05-23-2010, 03:07 AM | #3 |
Fun Stuff
Excellent, that is perfect. Thank you.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
05-23-2010, 07:44 AM | #4 |
Be careful accepting measurements from someone else's tape measure....
That little "tab" on the tape can be bent slightly (either in or out) and easily give you 1/8" variation. If you use the same tape for everything it doesn't matter, but in this case if it's truly critical you should be extra careful with the measurements. A lot of times I'll actually start at the 1" mark instead of using the tab just to make sure I'm getting a more precise value. -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well™" Build |
05-23-2010, 04:08 PM | #5 | |
Even though mine is a Suburban door, it could vary slightly from someone else's Suburban door depending on who built that door that day and if it was close to spec at the factory or a little off too. Either way, I re-measured at the 1" mark and got the same result (well, plus 1").
05-23-2010, 07:34 PM | #6 |
Fun Stuff
Thank you Beelzeburb. And thanks for the caution Greg72. Accuracy is important.
