Old 05-23-2010, 07:29 PM   #1
CrashBob
CrashBob's Avatar
Rear Control Arm Bushings...
Would someone please tell me the best way to get the old rear control arm bushings out?
Thanks,
CrashBob
"Life is all about ass. You're either covering it,laughing it off, kicking it, kissing it, busting it or trying to get a piece of it.
CrashBob is offline   Reply With Quote
Old 05-23-2010, 07:34 PM   #2
murgg
Re: Rear Control Arm Bushings...
i burned them...
murgg is offline   Reply With Quote
Old 05-23-2010, 08:06 PM   #3
dfwright
dfwright's Avatar
I used a propane torch on mine also. Be warned they can blow flaming rubber bits all over if you do it that way.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 05-23-2010, 09:04 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I used a press and some sockets...be careful about the thin sleeve on the outside of them, it has to stay...There are 2 ways to press em out. 1 Way WILL press the sleeve out, the other way will press the bushing out and leave the sleeve. Good luck!
John
1999 Toyota Tacoma 4x4
Old 05-23-2010, 09:16 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Some prefer to remove the rubber from the bushing using a small drill bit, repeatedly drilling holes all round the perimeter until the inner sleeve can be pushed out. If the outer sleeve needs to be removed and a press is not available, it can be cut on one end and "peeled" in toward the center using chisels and punches.
If you're going to burn the rubber out, it should be done outdoors over a bucket of water. The fumes are toxic and chunks of burning rubber are sticky and can be very dangerous if not controlled.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-23-2010, 09:21 PM   #6
oldblue1968chevy
burning em with a torch sounds like a way for my clumsy butt to get burnt and or passed out lol
John
Old 05-24-2010, 08:06 AM   #7
CrashBob
CrashBob's Avatar
Thanks to all.
I didn't figure there was a way to make them just fall out.
Again, this forum is the greatest!
CrashBob
Old 06-06-2010, 10:40 PM   #8
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I am replacing my rear trailing arm bushings now also, those just hammered out easy next will be the panard rod bushings. has anyone got a part numbers for the replacement bushings for these parts?
chevytruckluver is offline   Reply With Quote
Old 06-06-2010, 11:45 PM   #9
cokeb
Energy suspension #3.7104G, part # ending with G= black, R= red.
cokeb is offline   Reply With Quote
