05-23-2010, 10:30 PM | #1 |
Skinny's on the front ?
I did a search for this as well to no avail.
My '75 C-10 is the new recipient of a somewhat mild 496. The leaf sprung truck is now seriously traction limited (big surprise) --- I am now interested in taking it to the next level and a good friend of mine who is an accomplished "chassis man" has agreed to take on the challenge ---likely doing a ladder bar rear end with a 9 inch (but a 4 link has been discussed as well) I've got an idea of what we're doing with the rear and have a solid plan, --- but now i am contemplating cosmetics, so who makes a skinny drag racing front wheel in a 5x5? (15x4 or 15 x5) and if nobody does --- is there a 5 x 4.75 rotor that will fit the truck spindle ? This is more of a late 80's style Pro-Street build than a true racing truck, so appearance is everything (read: poser) but the truck does have a little bit of heat underhood Cutting a set down is a possibility i guess, but just figured i'd check for anything obvious first i should do instead
Are you retired too? Nonsense! I'm in my prime |
05-23-2010, 11:27 PM | #2 |
60-66 Nut
Re: Skinny's on the front ?
I don't know about the wheels, but according to another member here, a rotor from a '72 Impala will fit the truck spindle and is a 5 x 4.75" stud pattern.
05-24-2010, 12:14 AM | #3 |
Billet specialties, weld, centerline, Mickey Thompson... all of them make 15 x 4, 5 and 6's
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
05-24-2010, 12:24 AM | #4 |
Sunburst C10!!!
so the rotors will fit with the stock caliper and spindle?
Gage 1967 C10 Shortbed Stepside |
05-24-2010, 11:17 AM | #5 | |
---- fond some from Weld though
05-24-2010, 11:31 AM | #6 |
I believe the older Impala's had a 5 on 5 pattern also. The Camaro's,Monte Carlo's, Cutless,etc,had the 5 on 4.75
05-24-2010, 11:39 AM | #7 |
At the body shop.
Centerline will build 'em any way you want.
" That didnt make it any newer " " Dont antique the equipment " |
05-24-2010, 08:34 PM | #8 |
1975 impala is 5x5 that's what is on my truck right now
Justin weight 3480 with driver 1.35 60ft 6.13@111mph 1/8 mile 9.80@131mph 1/4 mile 434 small block all motor |
05-25-2010, 12:00 AM | #9 |
ShortBus KingPin
70 to 73 BB impala SS have 5x4.75 bolt pattern. They will fit the 67 to 70 c10's. You would have to double check your bearing sizes for the 73 and up trucks.
The pics is of everything off the impala brakes. calipers, rotors, bearings, pads, etc....
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) Last edited by midevil1; 05-25-2010 at 12:21 PM. |
05-25-2010, 12:10 AM | #10 |
60-66 Nut
Well I guess I should have done some research before I said anything......I was just going on what another member posted, and I didn't note who it was. Anyway, I did some research now and a '72 Impala does have a 5x5" wheel bolt pattern. The last year of the 5x4.75" wheel bolt pattern on an Impala was 1970 and they were a 2 piece hub and rotor. The '70 Impala uses the same wheel bearings as a disc brake C10 so the hubs should work, but I don't know if they will line up with the caliper. Also, out of 2 online sources I checked only one offered the rotor and it was $103.00. Then you would still need the hub.
Sorry for the misleading information
05-25-2010, 12:17 AM | #11 |
60-66 Nut
Looks like you posted while I was doing some final searching. I'm not aware of any Impala SS's in the '70-'73 years. Could that have possibly been the Monte Carlo SS's? or the Chevelle SS's? Those both had 5x4.75 bolt patterns thru '72. Which spindle did you use on your truck? Where did you find the hubs and rotors? Those look like 2 piecs hubs and rotors, is that correct?
05-25-2010, 12:19 PM | #12 | |
ShortBus KingPin
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
05-26-2010, 12:10 PM | #13 |
GM b-bodies from 71-76 & 91-96 have all been 5x5 from my experience. Not claiming to kno it all, just what I've seen on derby cars. anyway heres one, all you have to do is search. http://www.summitracing.com/parts/CLL-135401550/
05-26-2010, 03:38 PM | #14 | |
ShortBus KingPin
I do know that the GM car brakes are a cheap and easy upgrade for the trucks. All the vendors that I have talked too. Are not aware of this either.
05-27-2010, 10:03 AM | #15 |
a fool with no money
I have Weld draglites on the front.. 15x7 on a 5x5bp... I know, not the skinniest, but it's the skinniest i could get to match the rears without having to do a spindle swap.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
05-27-2010, 12:24 PM | #16 |
Sunburst C10!!!
they make weld draglites in 15x5 with 5 on 5 bp
http://www.jegs.com/i/Weld-Racing/92...oductId=746346
05-27-2010, 02:39 PM | #17 |
ShortBus KingPin
Holeshot makes 15x5 with 5x5 pattern also. Kinda pricey...
05-27-2010, 06:37 PM | #18 |
I cracked one of my 15X5 skinnies on my truck a few months ago during a race(small pot hole at the end of the track). My uncle also cracked one on his 67(swapped to car bolt pattern and used 15X3.5). When he talked to a Weld rep, they told him that's why they weren't making smaller sizes for truck bolt patterns. My uncle was driving his on the street though, so he knew it was just a matter of time before he broke one with his heavy truck. I don't know if it's that the trucks are too heavy or the wheels were too skinny, or the design or whatever...but they don't hold up to much abuse.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 05-27-2010 at 06:37 PM. |
06-01-2010, 11:37 PM | #19 |
Are those homemade federwell headers?
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
06-02-2010, 01:12 PM | #20 |
ShortBus KingPin
Look under "homebuilt header thread" for details and finished product.
06-11-2010, 12:30 AM | #21 |
Machinist
I just drilled my rotors... 5 on 4.5.... I got a killer deal on the wheels 15x3.5 aluma stars
