Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 05-25-2010, 10:20 PM   #1
71GMCer
Tach Problem...GRR
Hey all,
I recently just bought a Tach. Nothing to fancy but i needed one because my truck never came with one from the factory.
So anyways...after hooking up the main wires... my truck will not start!
I have an HEI distributor and there was already a green wire that ran from the tach plugin and looped around the firewall then came back to this little plug...
If you can notice where i snipped the wire...but that doesnt seem to be the problem becasue i took the time to reconnect the green wire there and still no cigar.
71GMCer is offline   Reply With Quote
Old 05-25-2010, 10:25 PM   #2
Leviticus
Shake and Bake!
Leviticus's Avatar
Re: Tach Problem...GRR
From the picture it looks like you have no power to the dizzy. There are two blades where you hooked your tach up, one is the tach lead, and one it the hot wire for the dizzy.
The green wire you cut may have been your hot wire, and a poor color choice by the previous owner
Get some 10Ga wire and run from the "Unfused Ignition" slot on your fuse panel to the "Batt/Bat" terminal on the dizzy and you should be golden.
Hope this helps.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-25-2010, 10:28 PM   #3
71GMCer
alright...well the two blades i belive were labeled...8+ and 8- or somthing or rather....and the instructions were to hook the green wire on the tach to the negative on the dizzy.
Old 05-25-2010, 10:33 PM   #4
Leviticus
Shake and Bake!
Leviticus's Avatar
If you look at the picture, you will see "Tach" and "Bat" written on top of the dizzy cap. The same way you hooked the green wire to the tach side, you need to hook a ignition switched 12V lead to the Bat side.
Without this wire, no vroom vroom.
Thomas Jefferson
Old 05-25-2010, 10:48 PM   #5
71GMCer
ah ok i think i figured it out...that plug in the fire wall seems to be a connector of some sort...the green wire was connected to it as well as a white wire....the green wire ran from the plug to the tach "batt" side of the cap....all i need now is some wire to run connect from where i snipped the old green wire to the Batt side of the cap and i should be rockin?
Old 05-25-2010, 11:06 PM   #6
Leviticus
Shake and Bake!
Leviticus's Avatar
If you can, run at least a 10Ga wire to the dizzy, it does help. Glad you got it figured out.
Thomas Jefferson
Old 05-25-2010, 11:08 PM   #7
71GMCer
alright..thanks for the help...why does it help with the gauge of wire?
Old 05-25-2010, 11:16 PM   #8
Leviticus
Shake and Bake!
Leviticus's Avatar
Bigger wire=less resistance=better voltage delivery=better performance. Also make sure if you don't run a new wire and hook into your old one that it is not the stock wire with the resistor on it.
Thomas Jefferson
Old 05-25-2010, 11:50 PM   #9
71GMCer
ya..im jsut gonna get some new wire and run it from that plug to the dizzy
