Old 05-27-2010, 07:37 PM   #1
93Chevy4x4
1985 Chevy S-10 355 Cam?
I have a 1985 chevy S-10 with a bored .30 over 350 vortec heads and a cam, with a 700 r4 behind it, with the original S-10 rearend. I didn't build the motor i had someone do it for me. I told him the motor was going into a truck so I think the cam he put in it is for pulling. It is really numb on low end it doesnt have the power it should have. When i hit the gas it will burn the tires for prolly 25-50 ft with no brake but its not what it should be. But when I hit the throttle at 50-60 hold on this thing will throw you right back in your seat and then some and still want to go sideways. What would be a good cam for more low end power?
-1993 Chevy 1500 2wd, reg. cab shortbed, V6, Dual Exhaust
-1993 Chevy 1500 4x4, Reg. Cab, stepside, Currently doing a frame up.
-1985 Chevy S-10, 4x4, 355, Tons of Extras.
-1989 Chevy S-10 ex cab, V6, parts truck.
-1995 GMC Jimmy 4x4, Vortec V6.
-2008 Chevy Aveo.
93Chevy4x4 is offline   Reply With Quote
Old 05-27-2010, 11:29 PM   #2
Matt Man
Matt Man's Avatar
Re: 1985 Chevy S-10 355 Cam?
if its a cam for towing you should see the opposite you should see more low end power and less high end power.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-29-2010, 12:38 PM   #3
Trick76
Living la vida broka
Trick76's Avatar
Comp XE268. with a dual plane and a 675ish vacuum secondary carb it will give you good low end. might help to find out what gears you have too because that 700r4 has a good first. your rear might be high.
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD
1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD
1984 C10 Longbed 6.2l diesel 700r4. ~SOLD
1985 GMC C20 350 700r4, ~under the knife
Trick76 is offline   Reply With Quote
Old 05-29-2010, 01:11 PM   #4
1helluva86
maybe youre looking at the wrong end oif the truck...you say it has no bottom end but all top. what kind of gears do you have in the rear end of the truck? stock gears arn't gonna help you off the line. you'd need a set of 3.55 or 3.73s.
1helluva86 is offline   Reply With Quote
