Old 05-30-2010, 09:25 PM   #1
ozman3803
Need some pics of bagged trucks on stock suspension
Ok, I have a 70 swb 2 wheel drive with trailing arms. I can't seem to find any pics on search engine. I would like to see what it would look like with stock suspension bagged with rear c-notch preferably with 20 inch wheels on all fours. Links or pictures and a little about it would be great.
ozman3803 is offline   Reply With Quote
Old 05-30-2010, 11:30 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Need some pics of bagged trucks on stock suspension
What do you mean by stock suspension? Are you saying no dropped spindles, or ?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-01-2010, 07:00 PM   #3
ozman3803
ok, guess I wasn't clear. How about 2 1/2 drop spindle with stock control arms with bag in front and for the rear bags on trailing arms with a c-notch installed. "Lucy" is my ideal stance was by N2BILLET I believe, but thought it would be great to get some other pictures.
Old 06-01-2010, 07:25 PM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
check my build for pics and some ideas and part #'s you need to drop your truck on bags
my truck is a 70 LWB and all my suspention is stock parts with a 2" C notch
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-01-2010, 07:41 PM   #5
ozman3803
cool, thanks hottrucks. I'm pretty sure I've seen your build through all the hours spent on here but I'll ck it out again for a refresher.
Old 06-01-2010, 09:11 PM   #6
Hottrucks
Hottrucks's Avatar
Believe it or not If I had to build it again I could do the suspention in a weekend...I just had to swap out the rear bags and it took me about an hour and a half
Old 06-01-2010, 09:19 PM   #7
Bennett68C10
Bennett68C10's Avatar
Pic of my old truck that I sold, had air ride front control arms but everything else was stock including trailing arms. Had a regular c-notch. Rear was actually hitting the bed floor.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 06-01-2010, 09:20 PM   #8
bad6772
Official Site Guitar Shredder
bad6772's Avatar
2 1/2 drop spindles..Stock lower control arms with plates...RE-7s front bags...Stock trailing arm rear suspension. 3 inch blocks...RE-7s rear bags. Bolt in C-Notch..<welded in.....255/35/20s front..275/45/20s rear......
bad6772 is offline   Reply With Quote
Old 06-01-2010, 09:57 PM   #9
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Check out this LINK
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-01-2010, 11:38 PM   #10
zammer
Addicted user
zammer's Avatar
Here's my 2wd blazer with a " ride tech " air kit with their C Notch... I have 3" bellteck spindles on the front too. The front will lay the stock crossmember on the ground without a bumpstop..
Not sure if this helps or not but it shows the frame height
kris
zammer is offline   Reply With Quote
Old 06-02-2010, 01:08 AM   #11
murgg
bad6772, what color is that??, cant decide between a green or orange paint job, liking yours though
murgg is offline   Reply With Quote
Old 06-02-2010, 01:13 AM   #12
BrianV
BrianV's Avatar
Just finishing mine up this week ill post some pics - i think its plenty low - the front crossmember is on the ground with it aired out
ill post some pics asap
BrianV is offline   Reply With Quote
Old 06-02-2010, 07:38 AM   #13
Hottrucks
Hottrucks's Avatar
Hey Bad you don't have a pic of those 3" blocks do you...I heard there is scrubline issues with more than 1.5"
Old 06-02-2010, 09:02 AM   #14
bad6772
bad6772's Avatar
I can get one....today....I think its with 15inch tires that I heard the same thing......? ButI am not positive.....Murg its a Stock Gm color that I doctored up some.....
Old 06-02-2010, 09:40 AM   #15
Ackattack
Ackattack's Avatar
see my avatar and/or click on build thread link in signature
Ackattack is offline   Reply With Quote
Old 06-02-2010, 08:51 PM   #16
avysittinon22s
avysittinon22s's Avatar
upper plates, 1 1/2 '' lower cups, 3'' drop spindles, 2 1/2'' c- notch, does push up on bottom of bed some, stock inner fenders front and rear
avysittinon22s is offline   Reply With Quote
Old 06-02-2010, 08:58 PM   #17
Hottrucks
Hottrucks's Avatar
I'd like to know what tire height in front I have 29" and I had to ditch the inners and I havn't even put my drop spindles in yet??
Old 06-02-2010, 09:07 PM   #18
ozman3803
Thanks alot guys, great lookin rides! keep the pics coming.
Old 06-02-2010, 09:17 PM   #19
ozman3803
Another question? So I'm looking at Mickey Thompson 29X15.00R20LT. My question is what would be the min backspace that I could run on say a 12 in. rim? I'll probably get a 10" rim and have is widened 2-3 in. Rim will come in a 5" backspace (looking at coy c-5's). Is this going to work? Or will I more that like have to narrow rearend?
Old 06-02-2010, 09:24 PM   #20
nibs
JRods Garage
nibs's Avatar
does adding tubular front lower control arms and rear trailing arms make a difference?
nibs is offline   Reply With Quote
Old 07-20-2010, 09:08 PM   #21
Lightnin2699
Lightnin2699's Avatar
Hey Man, Beautiful truck what size are those wheels on her?
Lightnin2699 is offline   Reply With Quote
Old 07-20-2010, 10:31 PM   #22
DZL1
One day.....
DZL1's Avatar
Heres my ride. Bagged all around. Front has 2.5 inch drop spindles, bags and CUT bag cups. Cut off an inch off of them. Might not sound like a lot but makes a big difference. Rear has bolt in c-notch, bags and NO cups, 2 inch lowering blocks. Picture is of truck aired out.
DZL1.
DZL1 is offline   Reply With Quote
Old 07-21-2010, 03:33 AM   #23
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Come on Tony... Don't you mean it's my color that you "doctored up". Please give credit where credit is due.
Murgg, the color is an R/M Diamont formula that I picked from their color chips... It was inspired by the stock olive green metallic available on these trucks in the day. Tony added some pearl but from what he told me, he basically used the exact formula that I sent him.
Here's mine with a 2" drop spindle and a leaf spring rear end with an axle flip, 3 leaves removed, 1" block and c-notch. Here are a couple of pictures with the suspension "aired out".
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 07-21-2010, 09:34 AM   #24
Lightnin2699
What size are your tires on those 22's out back? Thanks Man
Old 07-21-2010, 02:17 PM   #25
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Just so you can see both sides for comparison, here's my '69 running a 4.5/6" drop kit:
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
