Old 05-31-2010, 05:23 PM   #1
spavinaw
spavinaw's Avatar
My Cab Mount is gone
My driver side rear cab mount is gone. Rusted almost completely away. I have cut out most of it. I dont have the experience or $$$ to get it fixed. What will it hurt to leave it like it is?
spavinaw is offline   Reply With Quote
Old 05-31-2010, 08:52 PM   #2
8mpg
8mpg's Avatar
Re: My Cab Mount is gone
you can buy a new cab mount from *****************
They are not that expensive. Best off fixing it right the first time.
8mpg is offline   Reply With Quote
Old 05-31-2010, 09:05 PM   #3
ray_mcavoy
Hi spavinaw,
Got any pics of the damage? I'd be worried about the cab sagging in that corner and messing up the shape of the door opening.
That's pretty much what happened with my 77 GMC plow truck. The front driver side cab mount support (and floor above it) is pretty much gone. The whole cab leans forward a bit and the door opening is all jacked out of shape so the weatherstripping doesn't even touch the door in places. The missing cab mount transferred a lot of the load onto the front fender. That caused a chunk of the cowl area to crack and break around the fender mounting holes.
So what I'm getting at is don't just leave it. It'll eventually cause more problems. Even if you don't have the means to fix it correctly, at least rig up something to support the weight of the cab in that corner.
ray_mcavoy is offline   Reply With Quote
Old 05-31-2010, 09:33 PM   #4
spavinaw
spavinaw's Avatar
Thanks for the input. It sounds as if i need to address it now. So, what does this require or how extensive of a repair is this? Will it require removing the cab? Or can it be done without removing. Thanks for the input!
Old 05-31-2010, 10:09 PM   #5
8mpg
8mpg's Avatar
You can buy the supports here:
http://www.*****************/-63-87-f...hassis-mount-3
It would be a lot easier with the cab off, but I think you might be able to do it with the cab on IF you have an air chisel. You will need to knock out the stock rivets, then just slide the bracket in and bolt in the new one.
Old 05-31-2010, 10:19 PM   #6
spavinaw
spavinaw's Avatar
Ok. I guess I am wrong on what part I thought was a cab mount. Mine may still need replaced but these are not what I was thinking of. Let me do more research and I will get back with my question. Sorry but thinks for the info and link to the new cab mounts.
Old 05-31-2010, 10:21 PM   #7
71swb4x4
71swb4x4's Avatar
Is this what you need? http://www.gmcpauls.com/pictures/rearcabsupport.jpg
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-01-2010, 09:19 AM   #8
spavinaw
spavinaw's Avatar
Originally Posted by 71swb4x4 View Post
I do beleive it is. Now, can someone tell a begginer what it takes to replace these? Please? Just a quick overview would be good.
Old 06-01-2010, 12:56 PM   #9
my1st69
my1st69's Avatar
I am in on this i want to learn if i ever have to do it
Can someone also please post a pic of the full underside and show where all the mounts are?
my1st69 is offline   Reply With Quote
Old 06-01-2010, 05:41 PM   #10
michael bustamante
michael bustamante's Avatar
theyre cab supports right? Im subscribing as my 2 driver sides are rusted thru
1967custom
michael bustamante is offline   Reply With Quote
Old 06-01-2010, 05:43 PM   #11
spavinaw
spavinaw's Avatar
I beleive what we are now talking about are the rear cab mounts or supports? I hope some experienced guys or gals jump on this. It appears to have a lot of interest already.
Old 06-01-2010, 10:50 PM   #12
RustyDan
RustyDan's Avatar
Good thread...My truck is rusted bad underneath. Utah salted roads.
I have TWO cab supports going away. Thought I'd have to wait to pull cab as well.
Maybe not. I'm getting optimistic, We can do it!
Thanks man
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
RustyDan is offline   Reply With Quote
Old 06-01-2010, 11:03 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
LOL mines torn down (rocker cab corner etc off) its not gonna be too bad (i hope).
Cut off just this side of the mount (where its solid to weld) weld on and weld/bolt the other side . Now I havent done this yet im just guessing..check my build there may be some pics in there idk
John
1999 Toyota Tacoma 4x4
Old 06-02-2010, 01:25 AM   #14
my1st69
my1st69's Avatar
can you guys post some pics
Old 06-02-2010, 05:20 AM   #15
JimKshortstep4x4
Here is a picture of the cab floor with the sheet metal mounts intact.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 06-02-2010, 07:30 AM   #16
LockDoc
The Older Generation
LockDoc's Avatar
I believe there are two different styles of replacement metal cab supports, one is welded on and the other bolts on over the old support....
LockDoc
Leon
Old 06-02-2010, 09:18 AM   #17
oldblue1968chevy
So the diff. would be how many holes, and which one is preferred lockdoc?
John
Old 06-02-2010, 09:26 AM   #18
LockDoc
LockDoc's Avatar
Depends on what a person is doing with the truck. Over the top could be for a temp fix or a driver and the cut out and weld in the new for a correct rebuild... That's just my opinion though...
LockDoc
Leon
Old 06-02-2010, 09:31 AM   #19
oldblue1968chevy
If im spending this much time and money on rust repair im doing it and NEVER doing it again lol
so the right way is to cut em out and weld em back (no screwing)
John
Old 06-02-2010, 10:05 AM   #20
spavinaw
spavinaw's Avatar
Does the cab have to be removed for both of them?
Old 06-02-2010, 10:14 AM   #21
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I definitely recommend removing the cab if you are repairing this. If you atleast jack up the cab off of the frame, you maybe able to use the slip on cab supports. The best way to weld them in, is to remove the cab and lay it on it's back like how the cab is in the pic above. Also, I 100% agree with Leon, the slip on is a quick repair that is prone to rusting out again, as you are just "Band-aiding" over rust. The weld in is a more permanent fix and would look more original if that's what you are looking for. Either way, you need cab supports to keep the body level, and to be safe on the road. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-02-2010, 10:24 AM   #22
Quackaddict
"Hooked on Quack"
I am another in the long line of cab support replacement dudes. Funny thing is my passenger side is fine and my drivers sides are BAD. I was gonna cut out the rusted out parts, POR-15 what is left and then get the slip on replacements and weld them on. My truck is going to be a driver but I want to get the problem fixed.
Semper Fi,
Kevin
USMC
Quackaddict is offline   Reply With Quote
Old 06-02-2010, 11:16 AM   #23
oldblue1968chevy
thats probably why my cab feels like it tilts 2 ft side to side lol
John
Old 06-02-2010, 11:43 AM   #24
my67chevytruck
Under Construction
my67chevytruck's Avatar
I agree with Leon, and Trevor, get the weld in replacement piece vs. the slip on's
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-02-2010, 12:01 PM   #25
mr48chev
mr48chev's Avatar
Wes (here on the board) has them in his catalog http://www.classicheartbeat.com/cata...%20Support.htm
http://www.classicheartbeat.com/products1.htm
Sometimes it's better to call him than email him though but from experience if you get the online order in early enough it goes out the same day you order it.
