How Do I adjust the...
Mixture screws? What is everyone using to do this? Sockets won't fit, neither will any of my tools. It's a rectangle and I can't get it out with needle noses. Please help. I'm doing a rebuild. O yeah it's a Rochester carb. Thanks
Re: How Do I adjust the...
I have a newer 80-something Q-Jet carb on my 77 plow truck that has those oddball mixture screws too.
I ended up making a tool out of a scrap piece of brake line tubing. 3/16" I think. Just squashed the end a little bit in a vice to give it sort of a double-D shape that fits the heads of those screws. |
get a piece of rubber hose, small enought to fit tight. and adjust as needed, some auto parts store also carry the a set with a variety of small sockets with a long flexible scredriver type thingy.
You can get a double D carb adjustment tool from Autozone, Pep Boys, etc. for cheap. Still, I find the adjustment is still iffy getting it to stay in place while doing the adjustment, but if the carb is off the truck - should be no problem.
I thought the Quadra Junks were pre-set from the factory and had no provisions for adjusting the idle mixture without drilling something out or something funky like that.
Are you attempting a rebuild on the carb or the whole motor? If you're unsure of how to adjust the idle mixture on a Q-Jet you might as well forget about rebuilding it and just get you an Edelbrock.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
All About the BOWTIE
This is what I use to adjust the air mixture screws on my 84's Q-Jet... The tool has different sizes at both ends and flexes.. works like a charm... My dad got it from Napa Auto Parts in Visalia, Ca.. a while ago
CaliDude76 ![]() "... Being "SQUARE".. is where it's at...." ![]() Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..." Be exceedingly blessed today, my friends!... |
Thanks everyone for the ideas. Cali dude does one of those ends look like it would fit a rectangle?
Yes... sorry bro.. that one close-up didnt work to good....., but it does have rectangular ends on both sides.. apparently some carbs have different size deals to adjust. good luck
Ok Got my Carb put on and the truck is running, I just have one problem
Q-Jet carbs have a mechanical linkage connecting the primary (front) throttle blades to the rear (secondary) throttle blades. But there is a lockout mechanism that keeps the secondaries from opening if the choke isn't fully open. So make sure your choke mechanism is hooked up correctly and fully opening.
Q-Jet carbs also have secondary air doors above the secondary throttle blades. The air doors are spring loaded and only open based on engine airflow demand. So it's perfectly normal for the secondary air doors (at the top/rear of the carb) to stay closed or only open a tiny bit if you simply rev the engine with the trans in park/neutral. Is the backfiring something new since the carb rebuild? Or was it doing that before too? |
#11 | |
I've got my jets set a 2 and a half turns I'll be setting my idle adjuster on top of the carb to four turns tomorrow. I've got to fix that choke. It's suppose to open all the way up right(up and down)? Right not it opens up at it's fullest at about 100 degree angle. I feel like it should be more of a 90 degree angle. Please help. I need to get this think Smogged ![]() |
#12 | ||||
There's a good carburetor troubleshooting chart at: http://www.recarbco.com/technical/newtrouble.html that you might find helpful. |
#13 | |
![]() Last edited by CenValyCali; 06-06-2010 at 01:42 AM. |
Still plays with trucks
You really need a vacuum gauge to adjust the mixture screws properly. Set one screw for max vacuum then back it off until it starts to drop, then adjust the other the same way. Once you have done them both go back and do it again. The setting of the second screw will throw off the first a little.
After that is done set your timing to factory specs (unless you have a bigger cam) then adjust your idle screw to get the desired idle speed. Don't forget to disconnect and plug the vacuum advance hose when you set the base timing. If the mixture screws don't alter the vacuum then the passages behind them are gummed up and it needs cleaned out better.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#15 | |
#16 | ||
You mentioned a Check Engine light in one of your earlier posts so I assume you're dealing with an electronic feedback carb. Those do have a couple of adjustment screws accessible from the top for adjusting the lean and rich limit stops of the mixture solenoid. Those are the ones I wouldn't recommend messing with unless you have a specific reason and know exactly what you're doing. I think they're normally capped off from the factory anyway. The screw over on the driver side of the carb is the one you want to turn if you need to raise or lower the idle speed. Last edited by ray_mcavoy; 06-06-2010 at 07:05 PM. |
#17 | |
I knew it was something like that. I haven't looked at one in 10 years, I wised up and went to an aftermarket carb. It seems alot of people nowadays are wanting to run these things and I have no idea why.
