Old 08-06-2007, 08:50 PM   #26
pat66
pat66's Avatar
Re: Interior custom ac pics
WOW ! Slick truck, nice job
02 Blazer
66 lwb step
66 lwb feet :flagw
Working to live not living to work
RIP RS
pat66 is offline   Reply With Quote
Old 08-07-2007, 12:40 AM   #27
fercho71
fercho71's Avatar
nice truck coolair very clean
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 08-07-2007, 08:39 AM   #28
04Xrider
Registered thread killer
04Xrider's Avatar
SWEEEEEEEEEEEEEEEEEEEEEEEEEET!!!!!!!!!!!!!!!!
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 08-07-2007, 10:14 AM   #29
coolair
Thanks for the comments guy's......The AC system is from Vintage Air (I'm the tech support dept.) as I work for them I did get a pretty good deal and used as many parts that we offer such as the thermostat riser, hose clamps, Aeorquip EZ clip hoses, Front Runner drive system, Spal dual fans and the Gen II Compac evaporator. A typical complete AC system will start off around $900.00 and can go as high as around $3000.00 depending on the components you choose.
As far as the steering wheel, it was a close-out @ JC Whitney and the Sony radio/CD/XM receiver from Crutchfield.
If anyone has any AC questions or questions about the truck, let me know....best way to contact me is to email me - tech@vintageair.com.
Thanks again,
Mark
coolair is offline   Reply With Quote
Old 08-07-2007, 12:14 PM   #30
bedless66
ur truck is sweet man good job on interior
bedless66 is offline   Reply With Quote
Old 08-07-2007, 04:24 PM   #31
Sam_in_AZ
Junior Member
Sweeeeeeeeeeet looking truck! Congrats!
Great stance too. Is that about a 4/6 drop? and is it all mechanical - i..e. no bags or cutting frame??
64 Short Step 327 3spd
Sam_in_AZ is offline   Reply With Quote
Old 08-07-2007, 11:07 PM   #32
tjchevy1965
Very Cool..."Coolair" I would like to know a little more about the AC system as well. Do you have a website I can check it out at?? What is the size of that immaculate green motor?!
Sorry u already answered that!! Will that system work with factory Air? My tuck has air in dash from factory but lacks compressor, lines, evaporator, and coil...
"Hope you brought your wood screws...Ima blow ur doors off!!"
tjchevy1965 is offline   Reply With Quote
Old 08-09-2007, 09:57 AM   #33
OLDIRON69
Me too, I did not know you could get a system for $900
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 08-09-2007, 11:06 AM   #34
coolair
We do have a web site - www.vintageair.com - go to the online catalog to view all of the products available. We do not recommend mixing OEM components with new - it may work but who knows how well. Installing all new components that are designed to work together with the newer 134a refrigerant is a better way to go - you also get a 3 year warranty. If you have the FAC vents in the dash, you can connect our duct hoses to it to make it look original.
As far as price goes - for a complete cool only system such as our Slimline or Mark IV under the dash system along with the compressor, brackets, hose kit, safety switch, and condenser - it will cost just under $900.00. If you want the Sure fit kit or a universal Gen II system with related components, it would be in the $1100.00 price range. The more options you add, the more $$ it will cost.
Mark
Old 05-15-2009, 06:42 PM   #35
shrunken66stroker
shrunken66stroker's Avatar
Your truck looks great. I'm planning on getting a vintage air kit as soon as mine starts going back together. I live in Vegas so I'm definitely going to need it.
Where did you get your serpentine accessory kit and electric fan/radiator set up? I've been looking around for a while but haven't found what I want yet.
shrunken66stroker is offline   Reply With Quote
Old 06-08-2009, 03:32 AM   #36
Stinger 99
Stinger 99's Avatar
CoolAir. Great Job. Just ordered my AC today, your Cockpit Pics will help a
lot. But I'm really interested in your dual fan setup and shroud. What is it? Perfect setup. Got to have one like it.
Thanks in Advance
1966 Chev C10 Custom LB
Built 327ci, 700R4 Stage II, Mezier Elec Water Pump, Vintage Air, CPP Disks w/ABS, 22" Billets w/ Goodyear Eagle Low Pro's, Rear Pan, Hidden Hitch, Bagged
Stinger 99 is offline   Reply With Quote
Old 06-08-2009, 11:54 PM   #37
Tomsriv
Tomsriv's Avatar
Looks real nice! Like a modern AC install.
'65 Chevy shortbed stepside.
Tomsriv is offline   Reply With Quote
Old 06-09-2009, 07:37 AM   #38
scotts62
One day...
scotts62's Avatar
Very nice setups!
Scott
93 crew cab build
Project 62
Old 06-09-2009, 01:51 PM   #39
protrash64
Resistance is Futile
protrash64's Avatar
Thanks in Advance
This thread is 2 years old.......dug up from ancient history.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-09-2009, 02:10 PM   #40
scotts62
One day...
scotts62's Avatar
i didn't even notice that...
Scott
93 crew cab build
Project 62
Old 07-07-2009, 02:47 PM   #41
GR82BME
GR82BME's Avatar
coolair, what type of bracket are you using on the front of your motor for the accessories?
GR82BME is offline   Reply With Quote
Old 07-07-2009, 09:55 PM   #42
coolair
Vintage Air Front Runner - available for SBC, BBC & LS Chevy engines
Old 07-09-2009, 08:11 PM   #43
RED65
RED65's Avatar
very nice
RED65 is offline   Reply With Quote
Old 07-09-2009, 09:02 PM   #44
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
What did a set up like your run? and where you at in Tx?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-10-2009, 09:42 AM   #45
coolair
A Front Runner is around $2000.00 which includes the compressor, alternator, water-pump, pulleys, PS pump, belt and spring tensioner. The AC system will start off about $1000.00 and could go up from there depending on the options you choose.
I'm in NE San Antonio.
Mark
Old 07-11-2009, 11:02 AM   #46
64c20crewcab
64c20crewcab's Avatar
mark, very sweet setup!
..............................._________
......___________//___[[___{\ _____
...../__(_(O)_)___/____/____/_(O)_/
1964 C20 Long Stepside 3 Door Crew Cab
- Armbruster-Stageway Conversion
Y2K INDN Chief
"ONE OF A KIND, NOT ONE OF THE CROWD"
Aug 2010 - Front end frame cleanup & engine swap done!!!
June 2011 - Rear end bagged
Sept 2011 - Rebuild motor top end
Sept 2012 - Parked and slowly working on it.
Aug 2013 - Front end bagged - finally!
Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas...
Here is my build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=335427
64c20crewcab is offline   Reply With Quote
Old 07-11-2009, 05:18 PM   #47
Dinos63
chevy only
Dinos63's Avatar
that is a really bad A$$ truck
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 08-26-2009, 11:02 PM   #48
sixtyfour
Zombie Killer
sixtyfour's Avatar
Very nice.....
1964 C10 Long Step
sixtyfour is offline   Reply With Quote
Old 05-30-2010, 03:26 PM   #49
sixtyfour
Zombie Killer
sixtyfour's Avatar
Mark, do you have anymore shots of the install, I'd like to see where your a/c and heater lines exit the firewall.
Mike
1964 C10 Long Step
Old 05-31-2010, 10:24 PM   #50
coolair
I'll try and take some pics this week..........Mark
