Old 04-30-2010, 01:11 AM   #176
v502
v502's Avatar
Re: 79 C10 swap with L92 with 6L90
Originally Posted by 87chevy.com View Post
the fans probally will need a maxi fuse... the mini fuses are not up to the job.
as far as the tach, i forgot what wire i tapped into, but mine works on i believe 4cyl mode... 8cyl mode doesnt work, and i think 6cyl mode isnt accurate.. dude i love the way the exhuast looks... ive been wanting to re re redo my exhuast but havnt had the modivation.. might have just found it. ... looking at your truck makes me wish i didnt pass up a 700$ 6.2L with no accessories... i told they guy nahhh like a fool...
Glad you like the exhaust 87chevy Its not done yet and probably can do it cheaper if u go without the cats, cutouts & mandrel bends pipes.
Man 6.2 for $700 thats a steal man i would buy that and store it even if i had one in my truck.
Yeah about the fans fuse that's what i thought. The esclade uses something in same size as maxi fuse too. I don't understand why the ppl i sent the harness to didn't do that
About the tach i haven't really looked in it at all. I investigate in it when we take it to the tuner shop to figure out the tune.
v502 is offline   Reply With Quote
Old 04-30-2010, 10:06 PM   #177
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
went though a couple of diagrams for the 6.2L and couldnt find the white tach output wire that the 5.3 and 6.0's have... looking at the cluster pigtail connector, it might be a stupid bus signal. not 100% sure on that one. I wish I knew how to create a bus signal so the computer knows what im "saying"... ive wanted the tow/haul feature for the longest time...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-01-2010, 12:32 PM   #178
v502
v502's Avatar
Picked the truck on Friday Guy got over 400 rwhp on the dyno and damn the truck is scary anyhow i love the power and 6 speed is awesome.
Took the truck to the empty parking lot 10 mile away from the city and had little fun and to make sure everything is fine Enjoy
Old 06-01-2010, 12:42 PM   #179
nlped
nlped's Avatar
Yeah, that's pretty d@mn impressive! Now, don't blow it up!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-01-2010, 12:54 PM   #180
v502
v502's Avatar
Thanks nlped but sad to say it leaked oil out of of exhaust and fuel from somewhere around the gas tank after that day I Just sent it to the shop 1 hr ago
I think its a valve seal cause the truck works flawlessly and its not dripping oil now weird but still need to check out the fuel leak.
Old 06-01-2010, 01:37 PM   #181
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Damn, if someone beat me like that I'd probably leak some oil or something out my exhaust too! Sounds wicked.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 06-01-2010, 01:43 PM   #182
68 TT
Still plays with trucks
68 TT's Avatar
Now it really needs those new tires.
Great job getting it all together.
I hope it turns out to be something simple for the oil & fuel leaks.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 06-01-2010, 02:03 PM   #183
v502
v502's Avatar
Well this is like boot camp to make sure its really good and strong don't want drive it somewhere far later and breaking down on me if there is something wrong it will shows up instantly
Thanks 68 TT but I still got the front to go thru am planning on getting a set I need something with better traction i feel the truck wants to spin at 50mph when i hit on it its so easy to spin with these tires.
Old 06-01-2010, 02:15 PM   #184
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
WOW....thats a heck of a shake down run!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-01-2010, 05:29 PM   #185
menace121978
menace121978's Avatar
whoa! i cant believe that... i had to watch it 3 times! heck of a test run man sounded strong to say the least. congrats bro!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 06-01-2010, 05:47 PM   #186
JohnC
JohnC's Avatar
WOW!
JohnC is offline   Reply With Quote
Old 06-01-2010, 07:49 PM   #187
Cherub
Cherub's Avatar
eeeeeewwwww-wwwweeeeee thats a nasty
Cherub is offline   Reply With Quote
Old 06-01-2010, 07:56 PM   #188
draggin86
draggin86's Avatar
**** my life that is insane
draggin86 is offline   Reply With Quote
Old 06-01-2010, 10:50 PM   #189
3r!c84
Badass
3r!c84's Avatar
wow!!!!!!!!!!!!!!!!!!!!!!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 06-01-2010, 11:40 PM   #190
mcbassin
Still Learning
mcbassin's Avatar
HOLY SHEET! Wow! Glad your buying the tires!
Old 06-02-2010, 12:55 AM   #191
LEEVON
Moderator
LEEVON's Avatar
Nice smokeshow!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 06-02-2010, 11:00 AM   #192
v502
v502's Avatar
Thanks Menace
Its one fun truck cant take my foot of the throttle. Hopefully will see your truck on the road soon i cant wait.
Its called Reliability Testing 101
Originally Posted by JohnC View Post
WOW!
Originally Posted by LEEVON View Post
Nice smokeshow!
Glad you guys enjoined the video
Old 06-02-2010, 03:33 PM   #193
JohnC
JohnC's Avatar
Originally Posted by v502 View Post
.....Glad you guys enjoined the video
Probably about as much as you did making it.
Old 06-02-2010, 05:12 PM   #194
Bubba's79
Bubba's79's Avatar
Are you running vvt or not
1979 C10 SWB 390CI/350 3.73GEARS
Horsepower sells motors Torque wins races!
http://67-72chevytrucks.com/vboard/s...d.php?t=397626
Bubba's79 is offline   Reply With Quote
Old 06-04-2010, 11:45 PM   #195
rongstad
Future: 86 on GenIV power!
WOW nice video.......!!! CONGRATS!!!
rongstad is offline   Reply With Quote
Old 06-05-2010, 09:46 AM   #196
silvereagle07
silvereagle07's Avatar
Man what a test run! Found out what was leaking yet?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-06-2010, 05:55 PM   #197
v502
v502's Avatar
No am not running vvt.
Thanks Man
Yeah the truck is out i got it on Friday sorry didn't post anything couldn't take my a@@ of the seat i been driving
The oil leak was oil cooler lines just a seal.
I been working on the interior so soon i post some pics its almost done.
Old 06-07-2010, 11:26 AM   #198
silvereagle07
Cool man! Glad it wasn't something major after all that work.
Jeramy
'85 Chevy 4X4 SOLD
Old 06-07-2010, 12:08 PM   #199
STOCKISH
STOCKISH's Avatar
Awesome, glad it was a simple fix.
--Josh
Old 06-07-2010, 06:51 PM   #200
menace121978
just shows these motors are strong as hell
"Dennis the Menace"
6l90, l92, swap
