Old 06-01-2010, 09:44 PM   #1
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
starter/flexplate problem
My buddy bought a 72 truck cause the previous owner couldn't start it.(he bought it without hearing it run) The starter barely and i mean BARElY touches the flywheel. It makes that terrible grinding sound. We went to all the auto parts stores and discovered it's probably NOT the starter.
The only thing we could figure is the flywheel is on backwards. It's a NOT original 305 in it with a 350 tranny.
here's the question and a pic. IS THE FLYWHEEL ON BACKWARDS?
beebster is offline   Reply With Quote
Old 06-01-2010, 09:46 PM   #2
beebster
beebster's Avatar
Re: starter/flexplate problem
the pic is me directly under the truck, i removed the other bolts and took the pic before removing the last one.
Old 06-01-2010, 09:51 PM   #3
beebster
beebster's Avatar
Another pic.
I'm pretty sure it's backwards.
Old 06-01-2010, 09:56 PM   #4
crapy67
White wall terror
crapy67's Avatar
From the pics it looks like its in backwards to me.
crapy67 is offline   Reply With Quote
Old 06-01-2010, 09:58 PM   #5
beebster
beebster's Avatar
thanks crapy, let's see how many more think so.
Old 06-01-2010, 09:59 PM   #6
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
It is on backward. While you have it off, check to see if it's the correct one for the 305. I've never seen or heard of one being on backward untill now.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 06-01-2010, 10:05 PM   #7
beebster
beebster's Avatar
thanks camaro, good point.
i dont think he/we even know if it's a 305 or 350.
time for me to ID this motor.
Old 06-02-2010, 12:31 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It's on backwards... the "dimples" need to be towards the torque converter.
I'd never heard of it as much as I hear about it on this site.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-02-2010, 12:39 AM   #9
jbristo67
resident oilfield trash
jbristo67's Avatar
They aren't different from 305 to 402. I have put one on backwards before. I didn't figure it out until I went to bolt up my converter. I was 19 and not to expierenced at the time. Lucky I was using an over head lift with a tranny Jack so it litterally took 10 min to drop the tranny and fix it. I put that tranny in twice in 45 min thanks to the lift
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 06-02-2010, 02:21 AM   #10
beebster
beebster's Avatar
thanks jbristo and gasoline!
everybody pretty much agree's it's on backwards and i agree too.
jbristo67, you remember the andy griffith episode where gomer has to work on some guys car but needs to stay at the jail? He ended up taking the "whole" car apart and putting it back together "inside" the jail. LOL
when you said that about dropping the tranny twice in 45 min, thats what it reminded me of. ha ha.
Old 06-02-2010, 06:47 AM   #11
dwaite72lnghrn
Check the tooth count, If it is barely touching the starter. It could be a 12 3/4" flex-plate off a car with 153 teeth, Instead of a 168 tooth 14" for a truck.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-02-2010, 08:53 AM   #12
haysonj
haysonj's Avatar
I just posted about this 2 days ago, I was lucky and caught it while the engine was out of the truck. It is backwards the raised dimples go toward the converter.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 06-02-2010, 10:13 PM   #13
beebster
beebster's Avatar
thanks everybody that responded! problem solved.
the truck is fixed and running. Needs timing to be adjusted but the good part is that there is NO screeching or noises coming from the starter/flexplate.
The only bad part is tranny fluid in your hair (spilled a bunch removing the lines), damm i hate that. LOL
Old 06-03-2010, 12:27 AM   #14
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I did the same thing with the throwout bearing on the Blazer. First time I ever put a manual transmission and transfer case in. Then it was the second time I ever did it!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-03-2010, 02:50 AM   #15
raycow
Ya know, I'm still scratching my head on this one. Isn't the bolt pattern asymmetrical, so the flywheel can go on only one way? The flywheels for some engines have a weight on them, so this would have to be a requirement.
Ray
raycow is offline   Reply With Quote
Old 06-03-2010, 03:32 AM   #16
beebster
beebster's Avatar
you would think that, but believe me i found out that you CAN put a flywheel on backwards. ha ha.
once i turned that flywheel around it looked and started the way god and GM intended it to , perfect.
right now i'm in the process of taking off that holley it came with and putting a Qjet.
Love them Qjets.
man, i love it when a plan comes together and works out right.
my buddy is happy with this truck and i'm glad to be able to help out.
