Old 06-02-2010, 09:18 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
NEW Porterbuilt Bolt-in C-notch
I thought I would post up some pics of our new two piece bolt-in c-notch. I have been trying to find the time to finalize this thing for quite a while now… finally buttoned it up a couple weeks ago! This notch will be part of a complete mild drop system we will be releasing shortly, or we will be selling it separately for $249. This isn’t just an ordinary bolt-in c-notch… I put lots of thought into its design to ensure strength, and ease of installation. The fit on these notches is the best you can find in a production notch. We use factory frame-rail sections as a fixture to build them. Its two-piece design make installation a breeze. It locates using the two factory shock cross-member rivet holes on the top of the frame-rails, and then several holes are drilled. The first notch section can be used as a template and a support to cut the notch out of the frame-rails…. no more cutting, test fitting, cutting, test fitting, cutting… you get the picture! Once the frame section is removed, the lower notch will bolt in to the side and bottom of the rails. The lower section uses factory rivet locations on the bottom side of the frame, and also incorporates an air bag/spring plate (making it easier to drill the frame for mounting the air spring). The factory spring stiffeners remain in the chassis, keeping this baby as strong as possible. I will post more pics of the notch once I complete the mild drop kit I was referring to. There’s also more pics on my site for those who want to see more.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-02-2010, 09:21 PM   #2
70chevytruck
Re: NEW Porterbuilt Bolt-in C-notch
Looks like you need to work on your welding skills...
70chevytruck
70chevytruck is offline   Reply With Quote
Old 06-02-2010, 10:40 PM   #3
matt67350
matt67350's Avatar
Looks good. Thanks for all the hard work to make a system that is safe and affordable.
Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 06-02-2010, 11:09 PM   #4
n2billet
Village Idiot....
n2billet's Avatar
Not going to show pictures of the shock mount bar?
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 06-03-2010, 12:13 AM   #5
made2drag
made2drag's Avatar
very nice. another sweet and super strong peice of engineering from the master!
made2drag is offline   Reply With Quote
Old 06-03-2010, 12:20 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
We'll save that for another day....
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-03-2010, 12:24 AM   #7
jmedero
jmedero's Avatar
Please share the shock x member.... I was staring at mine today about to chop it out. I held back bc I did not find a better option without fabing one up. Lol
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 06-03-2010, 12:30 AM   #8
PBFAB.COM
PBFAB.COM's Avatar
There is a better option! Just not many people know about it yet!
I am getting ready to release a new mild drop kit that will incorporate a pretty slick shock mounting system. It keeps the shock angle where it needs to be (close to vertical) in order for the shocks to function properly. The shock relocator portion of the kit is designed to work with my tubular trailing arms... but I am planning on building a version that will also work with the factory arms as well. I plan on letting the cat out of the bag shortly... and will be leaking some more pics over the next few days.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-03-2010, 12:46 AM   #9
jmedero
jmedero's Avatar
Thanks man.
Old 06-03-2010, 01:19 AM   #10
8mpg
8mpg's Avatar
Awesome setup. I really like the ability to draw your cut lines accurately. Having the bag fitting cut outs also rocks. Drilling 1/4" steel along with the frame for a mount sucks.
8mpg is offline   Reply With Quote
Old 06-03-2010, 02:00 AM   #11
PBFAB.COM
PBFAB.COM's Avatar
It's definitely a lot of work drilling those holes! This set-up will allow you to use the lower notch plate as a template to drill the holes. You will still have to drill through the reinforcement plate/frame-rail/and shock x-member plate.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-03-2010, 09:15 AM   #12
1stchevy
1stchevy's Avatar
Very slick setup....just like all of your other products.
1stchevy is offline   Reply With Quote
Old 06-03-2010, 09:54 AM   #13
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice product Nathan!!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-03-2010, 10:08 AM   #14
big_al_71
big_al_71's Avatar
It definetly looks easy enough even a caveman should be able to do it.....Awesome Work!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-03-2010, 10:52 AM   #15
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Top notch...no pun intended!!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 06-03-2010, 12:19 PM   #16
Hart_Rod
Hart_Rod's Avatar
Thanks man.
You might as well just go all the way and put a dropmember in...... Nice work Nate.
Hart_Rod is offline   Reply With Quote
Old 06-03-2010, 12:54 PM   #17
mclairmo
Those welds give me a special feeling inside my body. Awesome looking product.
mclairmo is offline   Reply With Quote
Old 02-07-2012, 07:52 PM   #18
bondo510
What would be the disadvantage of this set up with stock rear arms ?
bondo510 is offline   Reply With Quote
Old 02-08-2012, 11:14 AM   #19
gcburdic
Restoration Virgin!
gcburdic's Avatar
Nate...can these be installed with the bed on the truck???...How about installation on a suburban??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-08-2012, 11:21 AM   #20
shawno72
C/10 junkie
shawno72's Avatar
I have been wondering that myself, bed on or bed off??
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 02-08-2012, 11:55 AM   #21
PBFAB.COM
PBFAB.COM's Avatar
The bed has to be removed in order to access the top holes. I have a handful customers who have installed them in subs and blazers... and to be honest, I do not know exactly what appreach they took.
There are a few ways that it could be done are:
1. Remove or raise the body in order to access the top side of the frame/notch with ease.
2. Make access holes in the floor in order to drill/install the bolts on the top side of the notch.
3. 90* drill and lots of careful measuring to drill the holes from the bottom side of the upper frame rail.
ALL of these options would be a fair amount of work on a suburban or blazer, but in my opinion, the best would be option 1.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2012, 12:41 PM   #22
ColoradoK5
ColoradoK5's Avatar
Is there any pics of this setup on a Blazer?
ColoradoK5 is offline   Reply With Quote
Old 02-08-2012, 12:46 PM   #23
PBFAB.COM
PBFAB.COM's Avatar
I don't have any on hand, as I have not yet installed one myself on a blazer. I have a couple guys on the east coast who are driving their blazers with the stage 2 kits. I will see if I can get some pics.
We have one in the shop that will be getting a stage 2 rear kit with a Dropmember Mild front set-up... but it's gonna be a little while until the blazer is all back together.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 02-08-2012, 01:07 PM   #24
longbed67
longbed67's Avatar
How much does it weaken the frame rail structure by taking out the stock shock cross member like you did here, should a new cross member be put back in after you install this kit or can it be left out without any loss?
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 02-08-2012, 01:12 PM   #25
PBFAB.COM
PBFAB.COM's Avatar
We make the notch to where it can be used with the factory shock crossmember, or used with our shock relocation system as shown in the pic below:
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
