Old 06-07-2010, 04:24 PM   #1
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Amp line through firewall, where did you drill?
and how did you run your lines? only need 8 gauge for current amp, but may go bigger later
by drill, i mean through the firewall. Im thinking ill mount the amp under the seat.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-07-2010, 04:27 PM   #2
81ratrodc10
house of chevy's
81ratrodc10's Avatar
Re: Amp line through firewall, where did you drill?
i didnt drill a hole for mine went through the fender under weather strip for door and in
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 06-07-2010, 04:27 PM   #3
pcmcobra
pcmcobra's Avatar
I put my 4 gauge through where the rest of the wires go through, near/under brake booster
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-07-2010, 04:27 PM   #4
AceX
>130dB Moderator
AceX's Avatar
Mine comes in through the fire wall by where the heater hoses snake their way in. Its actually just under the a/c box.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 06-07-2010, 04:40 PM   #5
Goldfinger
Goldfinger's Avatar
I would run it from the battery down the frame to the drain plug then under the rug and up the firewall. i did this with my CB.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 06-07-2010, 04:40 PM   #6
87Bob
I came through the firewall and ran it along the tunnel hump. Just high enough that water wouldn't be a problem and jus below the top edge of the carpet.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 06-07-2010, 04:54 PM   #7
qu1cks1lver56
qu1cks1lver56's Avatar
I went under the truck and up through a hole I drilled in the floor, I hate running wires through the firewall in my truck, always a PITA.
qu1cks1lver56 is offline   Reply With Quote
Old 06-08-2010, 12:30 AM   #8
Walts_restoration
all good suggestions, im gonna have to go look my parts cab over i guess and see the locations you guys are talking about and decide what i like best. Thanks guys.
Old 06-08-2010, 11:05 AM   #9
dropd80s
dropd80s's Avatar
I allways put them there too.
dropd80s is offline   Reply With Quote
Old 06-08-2010, 11:08 AM   #10
Chevy623
Chevy623's Avatar
I just ran into this problem 2 days ago, my '82 had a nice open grommet by the fusebox with a hundred wires or so all running through it and i just made it 101 lol.
My '91 Blazer didn't have anywhere to run it through except 1 grommet with a single wire running through it and a plug, it also was next to the fusebox. out of necessity i pulled the plug out a bit and squeezed, and i mean squeezed the amp wire through next to it.
Jesse.
Chevy623 is offline   Reply With Quote
Old 06-08-2010, 03:07 PM   #11
78 Chevyrado
I did the same thing. if you do this, you dont have to try to hide a big power wire under your carpet... you can always see em. my amp is under my console so i just drilled a hole in the floor like 4 inches away from where it connects to the amp. I also used one of those watertight bulkhead connectors.
78 Chevyrado is offline   Reply With Quote
