Old 06-08-2010, 10:39 PM   #1
jasonhall
jasonhall's Avatar
The 69
I bought a 1969 short bed a few years back and now i should have some time and money to finally work on it. I plan on doing the suspinsion and drivetrain this winter and go from there. Right now it has a 454 with a 700r4 and I want to get rid of it and go with the newer 5.3 or something along those lines. Ive already got most of my Suspinsion stuff from porterbuilt both front and rear now I just need to install it..
jasonhall is offline   Reply With Quote
Old 06-08-2010, 11:08 PM   #2
mcbassin
Still Learning
mcbassin's Avatar
Re: The 69
Wow! did you buy the truck in that condition? Looks like a great start
Glad to see another Okie build too!
Old 06-08-2010, 11:14 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: The 69
We need some more pics.... Nice ride to start with for sure..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-09-2010, 01:28 PM   #4
jasonhall
jasonhall's Avatar
Re: The 69
Here are some more pics of the truck. I put the centerline wheels on it and lowerd it with a No limit fual cell I put in about 3 years back .
Old 06-12-2010, 01:16 PM   #5
jasonhall
jasonhall's Avatar
Re: The 69
Room full of goodness
Old 06-12-2010, 02:44 PM   #6
Hart_Rod
Hart_Rod's Avatar
Re: The 69
Great start! Boomer Sooner!
Hart_Rod is offline   Reply With Quote
Old 06-12-2010, 07:31 PM   #7
jasonhall
jasonhall's Avatar
Re: The 69
Ill let that slide, You have some cool trucks
Old 06-12-2010, 10:15 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
Re: The 69
Looks like a pile of parts!
Old 06-13-2010, 12:02 AM   #9
jasonhall
jasonhall's Avatar
Re: The 69
Yes it is, I have almost all my suspension stuff, just need to find a new motor and trans.
Old 06-14-2010, 07:04 PM   #10
5windowpickup
5windowpickup's Avatar
Re: The 69
You have all those parts and you haven't started yet ? What are you waiting for ?? J/K looks good!
Josh Hart
High Octane Hotrods
71 C10 Bagged work in progress driver
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912
5windowpickup is offline   Reply With Quote
Old 06-14-2010, 07:18 PM   #11
gixxerpymp
Re: The 69
more pics!
gixxerpymp is offline   Reply With Quote
Old 06-14-2010, 07:23 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
Re: The 69
Originally Posted by gixxerpymp View Post
more pics!
ditto!
Old 06-14-2010, 07:48 PM   #13
jasonhall
jasonhall's Avatar
Re: The 69
I know.. It's tempting.. Porterbuilt keeps coming out with new products that are hard to pass up.. Once Summer is over i'll get it started.
Old 06-14-2010, 07:56 PM   #14
5windowpickup
Re: The 69
Once summer is over ? I'd knock out the suspension now, keep the big block in it and rock it for the rest of the summer. Then do the LS motor in the winter. I find that when you make your projects a series of small projects instead of one big one they seem a little more obtainable but that just my .02
Josh Hart
High Octane Hotrods
Old 06-14-2010, 08:39 PM   #15
jasonhall
jasonhall's Avatar
Re: The 69
The 700r4 went out and I also want to run power steering after asking you about your manual setup. What all would I need to get a power steering pump on the big block?
Old 06-14-2010, 09:08 PM   #16
5windowpickup
Re: The 69
I'm just giving you a hard time. Don't change your mind based on my opinion alone. Do what you want to do. To do power steering you will need a power rack, line kit for the rack with rack fittings, and a pump, resivore, pulleys and brackets for a big block depending on which water pump you have, short or long. It may require some research to find which combination you need. You could go stock or aftermarket depending on what you want to get into or what you want to spend. I got lucky my truck already had power steering on it so I have everything I need when I switch it back over.
Josh Hart
High Octane Hotrods
Old 06-14-2010, 09:23 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
Re: The 69
looks and sounds like a cool project!
Old 06-14-2010, 09:58 PM   #18
mcbassin
Still Learning
mcbassin's Avatar
Re: The 69
Couldn't just change it to power steering gear box and add a pump? I know that sounds easier than done, but there should be some parts around to get it done.
Old 06-14-2010, 10:08 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: The 69
Great looking project; can't wait to see it come together!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-15-2010, 01:48 PM   #20
jasonhall
jasonhall's Avatar
Re: The 69
Getting rid of the big block has been a back and forth battle for me. Im ready to get the truck back on the road, but while its down I would like to make it easier to drive. Its hard to pass up the 5.3's.. They have low mileage motor and trans for 1800 bucks in the salvage yards..
Old 08-07-2010, 11:15 PM   #21
jasonhall
jasonhall's Avatar
Re: The 69
Im thinking about saleing the 454 and 700r4. The motor runs great with a small cam,new holley double pumper 850 and new hei stuff from msd. The 700r4 lost 3rd and 4th. Im wanting to sale it complete from carb to oil pan. I just droped 800 bucks in the carb and hei stuff. The carb has 5 miles on it maybe 50 on the hei stuff. Whats a good price for something like this?
Old 08-08-2010, 12:59 AM   #22
mcbassin
Still Learning
mcbassin's Avatar
Re: The 69
It sucks you dropped all that cash in the new parts, you know your lucky if you get half of what you gave for them. With that said, I'm not sure what these are going for? good luck with the sale.
Old 08-08-2010, 08:38 AM   #23
Hart_Rod
Hart_Rod's Avatar
Re: The 69
Drive it as is while you are gathering parts for a 5.3 swap...
Old 08-12-2010, 10:13 PM   #24
jasonhall
jasonhall's Avatar
Re: The 69
Got the bed off and strated to check out the parts...
Old 08-12-2010, 10:36 PM   #25
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: The 69
great looking project, if your going to sell the big block deffinently leave it in the truck and post it for sell, most people won't even consider buying an engine they can't hear run. If it runs well and doesn't smoke or use oil it would bring $1500 to $2000 around here.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
