Old 06-09-2010, 02:45 AM   #1
AZ Chev Man
Thumbs up fuel tank repair
anyone ever had a fuel tank repaired instead of replaced. Mine is really in bad shape inside. having trouble locating a replacement. found some places online about repairing them, but don't know if it is a trustworthy solution.
AZ Chev Man
1st Ride 1958 Chevy Apache
2nd 1972 C10
1968 Chevy P10 Step Van
'01 Blazer, '03 Astro
AZ Chev Man is offline   Reply With Quote
Old 06-09-2010, 04:56 AM   #2
harry
harry's Avatar
Re: fuel tank repair
i just put in a new one as it had pinholes all along the bottom and when i got it out i looked inside and it was thick with RUST all along the bottom of tanksweet as now
harry is offline   Reply With Quote
Old 06-09-2010, 06:51 AM   #3
cdowns
cdowns's Avatar
is your old tank leaking??
they arn't that hard to clean. i use a pressure washer to clean th cunk and residue from the 40years of crap. then look and see what it looks like if real bad then will treat with muratic acid{swimming pool chemical) tthen rince again with clear water let dry and if in doubt i coat with POR15 tank sealer. have never had any problems doing it this way and a pretty cheap fix
Old 06-09-2010, 10:12 AM   #4
hayhauler71
hayhauler71's Avatar
http://www.gastankrenu.com/
I have used this place a few times with a great outcome
hayhauler71 is offline   Reply With Quote
Old 06-09-2010, 10:49 AM   #5
junkyardjohn
junkyardjohn's Avatar
IF IT'S A REGULAR OLD BEHIND THE SEAT TANK, I'LL BET THAT YOU CAN FIND ONE FROM A MEMBER THATS FAIRLY LOCAL FOR FREE OR NEXT TO FREE. I'VE TAKEN DOZENS TO THE CRUSHER OVER THE YEARS BECAUSE I COULDN'T GIVE THEM AWAY. WITH ALOT OF PEOPLE GOING WITH BEHIND THE AXEL TANKS, THERE SHOULD BE PLENTY OF GOOD USED ONES AROUND. ANOTHER GOOD SOURCE IS BONE YARDS. THE EPA MAKES MOST (IF NOT ALL) JUNKYARDS DRAIN & REMOVE THEM BEFORE PUTTING THEM IN THE YARDS TO PART OUT. ALOT OF BONEYARDS JUST PUNCH HOLES IN THE UNDERSIDE TANKS NOWADAYS TO DRAIN THEM, BUT THEY USUALLY DON'T PUNCTURE THE BEHIND THE SEAT TANKS. SOUNDS LIKE A GOOD TIME TO THINK ABOUT INSTALLING A UNDERBED TANK. A SIMPLE & VERY WORTHWHILE UPGRADE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-09-2010, 10:52 AM   #6
72mistressc10
72mistressc10's Avatar
As 'junkyardjohn' said. I have an extra behind the seat tank. I am a local Glendale resident too so let me know if you need that type.
1972 C10 LWB Cheyenne Super
God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
........................__
..........._______ |__\__
..........|__(O)______(O)]
72mistressc10 is offline   Reply With Quote
Old 06-09-2010, 11:31 AM   #7
AZ Chev Man
wow what a great bunch at this forum. thanks all of you. sorry didn't state before, my tank is the type behind the rear axel. 30" wide by 13" tall by 19" deep.
Thanks for the offer 72mistressc10. wish that would work.
AZ Chev Man
2nd 1972 C10
Old 05-04-2011, 03:40 AM   #8
AZ Chev Man
Thumbs up Re: fuel tank repair
Haven't been on in a while... Update on the 68... Found a new replacement fuel tank at a pretty neat place called Brothers in Southern California... Replaced the tank and it solved the problem....Apparently the inside of the old tank had been refinished years ago and was peeling off and getting into the fuel causing so many problems. Humbled to say its up and running great...starts right up and runs like a champ...Thanks for all the help out there!!
AZ Chev Man
2nd 1972 C10
fuel tank, gas tank, gas tank repair, p10, rusty gas tank
