Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-09-2010, 02:23 PM   #1
midevil1
ShortBus KingPin
midevil1's Avatar
Hydraulic Roller Lifters
Got a brand new set in my 505 from Crane Cams and I seem to have an issue with several of them oiling and then not oiling. Anybody had this problem. This REALLY irritates me, considering they are $500+ dollars.
Anybody have secret to getting these things too stay oiled or did I get a bad set????
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 06-09-2010, 03:09 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Hydraulic Roller Lifters
"CRANE" hydraulic rollers???? Did they start making them again after S&S bought the name out of bankruptcy? Actually I didn't know Crane ever made lifters. I thought they were re-boxed Johnson-Controls lifters. But things change!
Are you sure it's the lifters and not the rocker arms restricting flow? Speaking totally out of my little smallblock world here, but I had a similar issue with a set of TFS roller rockers and a very high lift cam ( anything .7 is HUGE for us little SBC guys) Anyways the block had oil restrictors, and the top end oiling issue went away when I put a set of the old Crane Gold rockers on it and tossed the TFS crap. Broke a rocker is the only reason i changed them and was GLAD I didn't have to pull the motor and remove the restrictors.
Just something to think about.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-09-2010, 04:31 PM   #3
Schralper
Schralper's Avatar
I've had CompCam hyd rollers in my daily driver Burban 400sbc for 20K? miles, no problem. i'm only running a tiny .52 lift though.
what kinda springs/lift ya running?
could spring pressure be the issue?
i've had reg hyd lifters toasted due to excessive spring psi.
Schralper is offline   Reply With Quote
Old 06-09-2010, 04:44 PM   #4
midevil1
ShortBus KingPin
midevil1's Avatar
Cranes name is back. I dont know who is actually making them. I am running 688 lift and no more than 130lbs of spring pressure. It is a hyd cam so spring pressure isnt the culprit. Motor has been running great until last night, it started missing on number 5 and 7. Pulled the valvecovers and found intake lifters were not oiling. Had one on number 6 stop and then start again. I have Comp cams Pro magnum rocker arms. I am pretty sure it is the lifters because I have two cold running cylinders with good spark and slight fuel on the plugs. If I dont have oil at the top of the pushrods, then my valves cant be fully opening right???? I have a 30* difference in exhaust temps from cylinders 1 thru 7.
Old 06-09-2010, 05:10 PM   #5
midevil1
ShortBus KingPin
midevil1's Avatar
If I have to replace them. I am looking at either Lunati or Howards. Which do you guys perfer? Never used Howards personally, but I hear great things about them. They are American Made out of OshKosh, WI.
Old 06-09-2010, 06:58 PM   #6
shawnt
shawnt's Avatar
I would get a set of the Morel type lifters from Lunati, just my preference. Howards makes great lifters too though. I can hook you up with a guy who would take care of you if you want though. Just let me know. He's a valvetrain guru. As far as your lifter not oiling, I'm not sure, but you could have just gotten a bad set. I'll ask a few guys and see if they might know and get back to you on this Asap.
Shawn
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 06-09-2010, 08:30 PM   #7
djracer
djracer's Avatar
I would try to get them replaced or buy Morel.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-09-2010, 10:08 PM   #8
midevil1
ShortBus KingPin
midevil1's Avatar
I called about warranty. Deaf Ears on the other end of the phone line. Want me too pull them so they can have them torn down and inspected. AT LEAST 90 days for answer... NOT! Just wont buy from them ever again and will tell my story every chance I get.
Lunati and Howards look very similar except the Howards are beefier around the rollers and are rated to 300 rpms more. Which would help with my RPM band.
Old 06-09-2010, 10:12 PM   #9
midevil1
ShortBus KingPin
midevil1's Avatar
Shawn
Any info you can get is appreciated. I will be ordering somebody's lifters on friday.
Old 06-09-2010, 10:28 PM   #10
djracer
djracer's Avatar
how many rpms are you planning to turn?
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-09-2010, 10:56 PM   #11
midevil1
ShortBus KingPin
midevil1's Avatar
Cam is solid to 6500rpms. The Lunati's are rated to 6200 and the Howard's are to 6500. Granted it wont live around 6500, but I like to know in the back of my mind that I have the parts to take it. My short block is built for 1200hp, but changed my mind about twin turbo build about 8 months ago and just wanted a 600 to 700hp reliable street motor. I am planning on adding a 150 to 250 shot after some street miles are put on the motor. I am kinda paranoid with this early failure.
Old 06-10-2010, 12:12 AM   #12
Rodms
Rodms's Avatar
title says hydro lift last post said solid?
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 06-10-2010, 12:28 AM   #13
midevil1
ShortBus KingPin
midevil1's Avatar
"Solid" as in STRONG to 6500 rpms. Slang term on my part.
Old 06-10-2010, 08:14 AM   #14
shawnt
shawnt's Avatar
You can run solid roller lifters on a hydro roller FYI.
Shawn
85 SWB
7.39 @ 93
Old 06-10-2010, 08:48 AM   #15
midevil1
ShortBus KingPin
midevil1's Avatar
But I would have to change my springs, pushrods, and adjust the valves all the time. Love the simplicity of the hyd lifter and low maintaintence. If this truck was more "strip" than "street" I would have gone solid.
Old 06-10-2010, 09:02 AM   #16
shawnt
shawnt's Avatar
LoL, i was saying this because the guy confused when you said hydro roller @ first then "solid" the second
Shawn
Shawn
85 SWB
7.39 @ 93
Old 06-10-2010, 09:29 AM   #17
Alex1
Alex1's Avatar
Best ones! they make the lifters for Lunati.
Alex1 is offline   Reply With Quote
Old 06-10-2010, 02:47 PM   #18
midevil1
ShortBus KingPin
midevil1's Avatar
Shawn
Now I am confused....... Leaning toward Howard's lifters. Beefier around the cup and plunger and around the roller tip.
Old 06-12-2010, 12:29 AM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
A Over rev caused this one to not hold oil pressure Comp-Cams
KQQL IT is online now   Reply With Quote
