Old 05-31-2010, 01:05 PM   #1
jaros44sr
jaros44sr's Avatar
Hello, my name is jaros44sr and I have a problem...
Well it all started several weeks ago and I'm at a loss...
Seems like #4 cylinder exhaust rocker arm is sitting askew compared to the rest of them! Don't think its a bent pushrod as I spun the rod and don't see any wobble, maybe a collapsed or sticky lifter. Could just one rocker arm be worn out or out of adjustment? Seems like all the nuts are adjusted about the same depth. If its the rocker arm Jeg's has stamped roller tipped (1.6 ratio) on sale till the end of June for 90 bucks. Maybe worn cam lobe, but always thought it was # 7 or #8 that was the problem
I've used a probe and don't feel any burr on the valve stem above the keeper, so I'm confident that this is something that just happened recently. Maybe I should pull the intake to get a better look
People said not to pay attention to it, but that is just not me. If something is differant, I think it needs some sort of attention...lmk what you think
SB 350 with a hydraulic cam, probably well used engine, but idk. I'm sure it needs a rebuild, but just wanted to get the restore done with this engine in it
Any thoughts would really help, I don't want to ignore the situation
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-31-2010, 01:59 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Hello, my name is jaros44sr and I have a problem...
What is the compression in the cylinder in question? Is the rocker arm stud bent? Waht does the hardware look like on the arm...I.E. The ball and arm?
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 05-31-2010, 02:17 PM   #3
LONGHAIR
Askew which way? pictures? What year is this engine? Vortec heads?
The bent stud sounds the most likely from the discription at this point, but how would that have happened? The cam or lifter cannot effect the way the rocker arm sits, only the three points where it touches, the pushrod, the valve stem, the stud/ball can do that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-31-2010, 02:35 PM   #4
jaros44sr
jaros44sr's Avatar
good thoughts guys, bent stud, didn't think of that!
Haven't done a compression test yet
Haven't disassembled, so the condition of the parts are yet to be determined
No vortecs, year about 80's, askew to the rear of the engine. Pics to follow
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2010, 02:56 PM   #5
jaros44sr
jaros44sr's Avatar
2.130" outside demension on studs, #2 and # 4 cylinders
Please don't laugh at the condition of the inside of the engine, buildup was due to the PO running the engine with a leaking fuel pump
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2010, 02:59 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Looks like a lot of metal in the oil... I'd say some cam lobes are going flat.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-31-2010, 03:37 PM   #7
bigblock52
Is the pressed in rocker arm stud starting to pull out of the head?
bigblock52 is offline   Reply With Quote
Old 05-31-2010, 04:47 PM   #8
jaros44sr
jaros44sr's Avatar
didn't know they were pressed in, but that makes sense
SAFETY FIRST
AS usual, off topic
Jim
Old 05-31-2010, 05:14 PM   #9
LONGHAIR
It looks like a combination of a stud pulling out and a flat cam. All of that metal came from somewhere....and gas-diluted oil would be a good reason for a bad cam.
Old 05-31-2010, 06:05 PM   #10
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Wish I had some advice, but I'm just glad you found it now instead of running down the road several hundred miles from home!
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-09-2010, 01:53 AM   #11
jaros44sr
jaros44sr's Avatar
Thanks red
Well, I did some disassembly....seems like there is so much buildup the push rod won't move side to side, keeping the rocker arm locked off center
Studs don't look bent or pulled out, and pushrod is not bent
My question is, are all SB's the same size rocker arms and push rods (305 & 350), I don't know what engine is in there and search tool for your block numbers is to confusing to use. Possibly due to CRAFT
any thoughts, opinions?
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2010, 09:05 AM   #12
RustyParts
RustyParts's Avatar
You might want to check the stud Jaros, if that rocker has run like that for some time it usually cuts a groove in the stud. Good luck.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 06-09-2010, 11:08 AM   #13
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Totally. You can see it here.
Happened to me! Pulled studs, tapped, and installed screw in studs. My rocker had eventually slipped almost all the way off the valve and was kind of jammed into the gouge. Had this in a couple of spots, some studs that were pulling, and a few bent push rods. I suspect the PO smashed the skinny pedal to the floor too often and too long.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 06-09-2010, 11:14 AM   #14
1949gmc
Hi Jim-
All small block Chevys, from the factory, have the same rocker arm ratio (1.5) and pushrod length (7.794 or 7.8). As far as the block numbers go, get the casting number from the back of the block or the suffix code from the front of the right bank, where the head and block come together. The casting number will be seven digits, like 3970010, and the suffix code will be something like V0629TBG. Post what you find and we can tell you what you've got. In fact, since you've got the valve cover off, post the casting number for the head, too.
Only things I can think of are the press in stud is pulling out or the rocker arm pivot ball is in upside down.... the top of the valve might be bent.... could be a worn valve guide, but that'd be a helluva lot of wear.
Have you ever had this engine running or have you heard it run? Post a picture, if you can, of those two valves from a straight on view.... what it would look like if you were leaning over the fender. I'd like to see those valves better.
Ray
1949gmc is offline   Reply With Quote
Old 06-09-2010, 11:18 AM   #15
junkyardjohn
junkyardjohn's Avatar
GOOD ADVICE. IF THERES SIVER GUNK UNDER YOUR VALVE COVER, YOU CAN BET YOUR OIL GALLYS ARE FULL OF IT TOO. ALL THOSE LITTLE SHAVINGS JUST MULTIPLY LIKE RABBITS AS YOUR OIL CIRCULATES. THAT MOTORS LOOKS TO BE ON BORROWED TIME EVEN WITHOUT YOUR ROCKER PROBLEM. IT TAKE PLENTY OF CLEAN OIL FOR ALL THOSE LITTLE PARTS TO SLIDE OFF OF EACH OTHER SEVERAL THOUSAND TIMES EVERY MINUTE. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-09-2010, 01:32 PM   #16
GASoline71
GASoline71's Avatar
Only way to get all the particles out is to tear the engine down completely...
Gary
Old 06-09-2010, 02:00 PM   #17
jaros44sr
jaros44sr's Avatar
After you mentioned that, I went down and checked. Sure enuff, a slot about an 1/8" deep in the stud
Do you have to drill out the stud hole, or can you just tap it after you remove the stud. Do you need a bottom tap
Originally Posted by 1949gmc View Post
Hi Jim-
Ray
Camera batteries just ran out, pics will have to wait a day or so
Broke a piece of the hard carbon off and using a magnet to attract the carbon, sure enuff it moved the piece slightly. So we do have a big problem ready for rebuild...but not yet
here's the block number
75B595801 KO6 24 CMJ
o
r
1
will post up soon, gotta get to work
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2010, 08:46 PM   #18
jaros44sr
jaros44sr's Avatar
edited post # 17
SAFETY FIRST
AS usual, off topic
Jim
Old 06-09-2010, 09:01 PM   #19
sinned4me
on mine you pull out the old stud and mill the top of the stud boss to a certain height. it also depends if you are running guide plates. you then drill the holes on a drill press holding the head at the correct angle, tap the holes, and install the studs with thread sealant (there is coolant behind stud) and your done.
sinned4me is offline   Reply With Quote
Old 06-09-2010, 11:44 PM   #20
jaros44sr
jaros44sr's Avatar
Thanks for the info, was kinda hoping to do it on the engine. If that is the case, then I might as well change out to my extra heads
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2010, 12:29 AM   #21
wzuke
wzuke's Avatar
Replace the rocker arm with a self aligning rocker arm.
wzuke is offline   Reply With Quote
Old 06-10-2010, 12:43 AM   #22
jaros44sr
jaros44sr's Avatar
OK, I'm game...what's that and where do I get one
SAFETY FIRST
AS usual, off topic
Jim
Old 06-10-2010, 12:47 AM   #23
stevencvn72
Kill Bill...et
I never even removed my heads. Pulled the old stud. And tapped the hole very slowly using grease and a magnet to catch shavings. No it's not the right way, but it can be done. Oh yeah, if you use shoulderless screw in studs, there's no need to mill down the stud boss. Just use thread sealer and jam nuts.
-Steve
I Grease
'67 Chev stepper
Old 06-10-2010, 01:09 PM   #24
GASoline71
GASoline71's Avatar
Old school way would be to "pin" a new press in stud in place. Insert new stud and drill a hole through the side of the boss and through the stud... then tap in a roll pin.
Gary
Old 06-10-2010, 03:38 PM   #25
jaros44sr
jaros44sr's Avatar
Gary
That sounds doable, so are you able to tap in the new stud with a 3lb brass sledge
SAFETY FIRST
AS usual, off topic
Jim
