06-10-2010, 08:08 PM | #1 |
need info on a tranny swap
I have a 69 lwb chevy 1/2 ton with a 73' "car" 350 and I believe it is a saginaw 3 on the tree. What I need to know is what all I would have to do to put in a 700R4 in place of the 3 on the tree.
06-10-2010, 08:33 PM | #2 |
Cruzin
Re: need info on a tranny swap
you need a auto crossmember, tv cable, cooler lines, a radiator with cooler hookups or a add on cooler and driveshaft will maybe need to be modified, and a auto column or a shifter in the floor not hard at all i did my 71 last year
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-10-2010, 10:36 PM | #3 |
Junior Member
Flex plate and torque converter also.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-10-2010, 11:25 PM | #4 |
where is the cheapest place to look for all that?
06-11-2010, 12:47 AM | #5 |
Location: Aurora,Il ..born,raised and still live in the same house
if your lucky enough to have a "9 in. tail on that turbo 350,it'll be the same size as a 700r
so the driveshaft will be the same length. i'm doing the swap next spring, and i just bought a heavy duty,racing,1 piece driveshaft. One less thing to worry about. LOL
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
06-11-2010, 01:11 AM | #6 |
You will also need a block-mounted starter to match your flexplate. The stock manual transmission starter bolts to the bellhousing.
Ray |
06-22-2010, 09:02 AM | #7 |
Thanks for the help. I might be in over my head lol
06-22-2010, 09:11 AM | #8 |
Ok, at the risk of looking stupid, what's a tv cable?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
06-22-2010, 09:28 AM | #9 |
thats the cable responsible for engaging your overdrive gear. if it isn't setup properly it will destroy your transmission
1968 Chevy C10 swb fleetside 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) |
06-22-2010, 09:37 AM | #10 |
Is is a mechanical switch, or electronic?
06-22-2010, 12:27 PM | #11 |
TV means throttle valve. The TV cable is a mechanical connection between your truck's throttle linkage and the throttle valve inside the transmission. The throttle valve controls oil pressure in the transmission in accordance with the amount the throttle is opened.
Ray |
06-22-2010, 12:50 PM | #12 | |
If you're talking 4wd you need all the above plus the correct aftermarket output shaft, th350 to NP205 adapter, and a NP205 that originally came out of a truck with a th350.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Tags |
69 lwb, tranny swap |
