Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-12-2010, 11:43 PM   #1
dbmx66
water bypass problem, need help
its for on and sbc. the problem is that i got my hands on and edlebrock cnc ported victor jr manifold. and where you would plug the 2 water bypass hoses into the back of the manifold. the problem is when i look down the holes, the manifold gaskets are not open there, like they block the port off, is there anyway i can cut them out? or am i stuck taking the whole thing apart and getting new gaskets that have them cut out already? i would just cut them out, but i dont want pieces of gaskets to fall down in. whats ur opinion? thanks
dbmx66 is offline   Reply With Quote
Old 06-13-2010, 01:03 AM   #2
chevytruck1970
chevytruck1970's Avatar
Re: water bypass problem, need help
what's the brand and part# of the gaskets?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 06-13-2010, 01:15 AM   #3
dbmx66
i forget the exact number, but they are feel-pros
Old 06-13-2010, 10:55 PM   #4
chevytruck1970
are they light blue with darker blue stripes or are they black with blue just around the ports
Justin
1.35 60ft
Old 06-14-2010, 12:16 AM   #5
dbmx66
light blue
Old 06-14-2010, 09:18 PM   #6
chevytruck1970
you really need to get the felpro race gaskets the black ones with the blue around the ports pn#1205 or 1206 depending on the port size they both will have the open water ports your looking for
Justin
1.35 60ft
Old 06-14-2010, 11:07 PM   #7
dbmx66
damnit, those are the ones i had on it, then put these on with the new manifold because the old ones tore.
Old 06-14-2010, 11:23 PM   #8
dbmx66
well i fixed the problem, i sharpened a skinny piece of metal into a really small knife kinda thing, poked through the gasket, started cutting aound the hole, about 3/4 the way around i stopped, bent the piece up with needle noses, held the piece tight with the pliers and finished cutting it out, it worked well. im gonna take a small flexible tube the i can fit down the hole and vacuum it out, there isnt coolant in yet so i doubt if there were little pieces that fell off, that they didnt good far. i think im fine.
