Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-13-2010, 05:03 PM   #1
hotrod_991
hotrod_991's Avatar
best way to adjust rocker arms on allum. heads
I have a 350 bored .40 over with allum floteck heads, roads lifters mutha thumper cam and .50 push rods and sportsman roller tip rockers and I cant seem to keep the rockers in adjustment. Does anyone have any tips on adjusting them and maybe keepin em in adjustment other than a set of stud gurdles that I plan on getting when the money allows me to. Any help is apreciated thanks.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 06-13-2010, 05:33 PM   #2
rjs53
Re: best way to adjust rocker arms on allum. heads
For a small block Chevy (or any engine with a firing order of 18436572) you can set the valves by turning the engine over just two times. Bring the engine up to #1 firing (both #1 valves closed and the timing mark aligned with zero on the timing tab) and adjust as follows: exhaust valves 1,3,4,8 and intake valves 1,2,5,7 bring engine up to #6 firing(rotate engine one complete revolution) and adjust as follows: exhaust valves 2,5,6,7 and intake valves 3,4,6,8.
Method #2:
This is the one I use and it goes like this: when the intake valve on a cylinder has opened fully and is almost closed, adjust the exhaust valve of that same cylinder. When the exhaust valve starts to open, adjust the intake valve of that same cylinder. This method takes a little longer but it works very well. your rockers should have a jam nut to help keep them tight for proper adjustment also i would recommend doing this with the motor warm
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 06-13-2010, 05:54 PM   #3
hotrod_991
hotrod_991's Avatar
no jam nut but do have the poly locks with the allen style hole. Ill try the first method first and see how that works out. I read in a speedway catalog about a way to do it by rotating the motor 90 degrees between each two adjustements not sure whta the method is called tho. That was how i did it last time.
Also they way I was taught was the roll the rod between my thumb and index finger as im tightning the rocker till I feel it start to drag then 1/2 to 3/4 turn and lock em down. Does that sound about right?
Old 06-13-2010, 07:21 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I do it with the engine running! I recently did it to my ZZ4. Roller cam engines are zero lash.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-13-2010, 07:34 PM   #5
cableguy0
Method #2 that rjs posted is the best most accurate way to adjust the valves on any engine regardless of make. It works on any valvetrain setup. Theres not a need for a doing a running engine adjustment. If the valves are adjusted properly they wont need a running adjustment.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-13-2010, 07:54 PM   #6
rjs53
sorry couldnt think of the correct term POLY LOCKS my brain some times gets a jam nut regardles your rockers shouldnt be loosening up.
2003 Dodge 2500
1969 C10
Old 06-13-2010, 09:07 PM   #7
Marv D
Registered Truck Offender
Marv D's Avatar
DITTO! you can set preload on the lifters on the engine stand this way and never look back! Unless something wears unexpectedly, the hydraulic lifter will take care of it.
Here's the same thing said with a few more details
http://www.small-block-chevy.com/cb_6.htm
One suggestion, with a poly lock you have it made. Loosen the inside allen head lock, set the lifter on the heal of the lobe as described above and run the adjusting nut down with your FINGERS to zero lash. This works ideal because you can't go past zero lash with your fingers. Then add your 1/4 or 1/3 turn with a wrench. Another suggestion,,, don't get stupid with the inside allen head lock. Over tightening the lock is just good reason to break a rocker stud. It doesn't need anything more than a good T-handle allen wrench will supply. Too many guys want to use the wrench and JAM the crap out of the lock with a twist of the adjusting nut. That puts a big stress on the rocker stud at the base of the lock nut. If you tighten it that way, are putting a lot of stress on the studs with stiff springs,,,, a broken rocker surd should be expected. I'm not saying they can be left 'loose',,, but just don't get crazy with the lock
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-13-2010, 11:14 PM   #8
hotrod_991
hotrod_991's Avatar
thanks to everyone for thier input I am going to give it a try tomarrow morning if I have enough tools here at the house as I dont want to drive it with the loose rockers for fear of damage. motor has about 240 miles on it so far so dont want to risk anything. Ill do the finger to zero lash option. Would the stud gurdles be worth the money for a weekend toy? I plan on running it on the strip from time to time but mostly just raisin hell around town.
Old 06-13-2010, 11:47 PM   #9
rjs53
how high RPM do you plan on running what kind of lift does your cam have? If it's mainly for street i would use ARP screw in studs and call it good thats just me. I geuss the girdles are cheap insurance. you will need tall valve covers though
2003 Dodge 2500
1969 C10
Old 06-14-2010, 01:58 AM   #10
hotrod_991
hotrod_991's Avatar
I have tall valve covers already, and I plan on turning close to 6000 when i shift. my cam has .500 lift.
Old 06-14-2010, 07:49 AM   #11
bigsnookmaster
bigsnookmaster's Avatar
You don't need stud girdles. They stabilize the valvetrain and keep the rocker shafts from flexing. On a .500 lift they wouldn't be required.
bigsnookmaster is offline   Reply With Quote
Old 06-14-2010, 09:51 AM   #12
Marv D
Marv D's Avatar
Agree,, if it were a solid with a buttload of spring pressure designed for the .50 lift rule and 8000rpm,,, sure a stud girdle is cheap insurance. But not a hydraulic with only .5 lift and 6000rpm.... I bet you only have 95 to 110 pounds of seat pressure and probably not over 250 on the nose. Save the $ for something else.
Old 06-14-2010, 01:25 PM   #13
hotrod_991
hotrod_991's Avatar
ok thanks for the advise gentlemen. im going to atteck the rockers here in a few hours and ill post if I have any issues.
