pressure plate change. 72 jimmy
ok my next problem is the pressure plate is not realeasing. If I have to change this do I have to come in from inside the cab? I notice there is an access cover over the trans and transfer box.
Or is it not worth the hassle and just have the shop do it. ? |
I'm a poor spectator
Re: pressure plate change. 72 jimmy
It's pretty easy. The only part I needed help with was when I was putting the tranny/xfercse back in. It was just kind of akward to get it back up there by myself.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I was thinking about pulling the motor instead. Then at least I can pressure wash it.. However Ive never done this model before. last thing I want to deal with is nasty gear oil !
If you've never done it it's easy to pull it but putting it back in usually will require a little help to man the hoist while you or your friend is under the truck lining up the transmission main shaft into the back of the engine.
I miss this truck.
Pulling the motor, replacing the pressure plate, and re-installing the motor could reasonably be accomplished in a day with 2 guys. Quicker if you have air tools.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
ok got the seats pulled out, and the shell over the tranny removed.
Would it be easier to pull the motor and change the clutch assy or pull the tranny and T-box. I power washed the engine so its a bit cleaner. Or do I remove the drive shafts unbolt the the 4sp from the bell housing and move everything aft. then change the clutch assy...? |
