Old 06-16-2010, 10:32 PM   #1
71GMCer
Do physics apply?
I just did the intake manifold gasket and Distributor gasket and also plugged the oil pressure sending unit because it was all leaking (according to my mechanic)
It still leaks! So im just wondering if phyiscs apply here? Will it continue to drip until the thick sludge on the sides of the motor and tranny are all "dripped" off? Or is my mechanic just saying that to cover his rear?
Im quite curious because i know the rule is that when things heat up that they become liquified if there a solid, then to a gas, so will the old caked on oil and grease eventually drip away or should i plan on buying oil (again)?
I also did the oil pan and rear main seal so there is nowhere i can think it could be leaking from?
Matt
1970 GMC 1/2 Ton 4x4 350sbc SM465 NP205
71GMCer is offline   Reply With Quote
Old 06-16-2010, 10:45 PM   #2
vectorit
What?
vectorit's Avatar
Re: Do physics apply?
All that work and you didn't replace the valve cover gaskets?
Yes, if your engine is very dirty and oil soaked it will continue to drip until it's either cleaned off or dried up.
I suggest pressure washing the whole engine, engine bay, and under carriage. Once you have a cleaner engine, future leaks or a mysterious one will be easier to find and fix.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-16-2010, 11:01 PM   #3
71GMCer
yes i did sorry forgot to mention that! Got custom valve covers on
Old 06-17-2010, 04:44 AM   #4
tim21391
tim21391's Avatar
u mind showin us some pics that may help
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-17-2010, 04:50 AM   #5
cdowns
cdowns's Avatar
what applies is sound mechanical principiles. did you read a service manual? it's chock full. especially about the proper way to setup a PCV system is an interesting topic to aid in pressure management inside an engine
Old 06-17-2010, 06:18 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
get some engine cleaner and spray it down and wash all the old crud off. If it still leaks them its your mechanic. It cold still be leaking from any of the repairs, wash it down and check it for leaks. Ecessive blow by will force oil out the seals no matter how new they are, so it may be that.
Old 06-17-2010, 10:23 AM   #7
71tahoe
71tahoe's Avatar
If the intake valley was sealed using gaskets, get a new mechanic. They will almost certainly leak from the get-go. I've had the best luck applying a bead of silicone and letting it fully cure before cranking it up.
71tahoe is offline   Reply With Quote
Old 06-17-2010, 10:35 AM   #8
Ackattack
Ackattack's Avatar
x2
Ackattack is offline   Reply With Quote
Old 06-17-2010, 11:12 AM   #9
71GMCer
alright well im gonna clean it up this weekend....im always so nervous though about spraying water where it shouldnt be....so how "careful" do i need to be? I know obviuosly not to stick the nozzel in the carb or alternator or dizzy but how much water can get on those?
Old 06-17-2010, 10:06 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
The motor should be water tight as well as oil tight so spray where you need to. with the air cleaner on you can spray the carb as well. If you have HEI you shouldn't have a problem just don't soak it
Old 06-17-2010, 10:43 PM   #11
trusty72
trusty72's Avatar
x3 on the gaskets. dont spray the carb or dist.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
