06-17-2010, 01:18 PM | #1 |
Canister filter and electric pump
Do you put the filter between tank and pump or pump and carb?
Simple question and what I would think is between tank and pump. What I don't understand is the pump is rated at 110 GPH but the filter is rated at 90 GPH. If the filter goes between tank and pump will it cause problems being a lessor GPH rate? Will the pump draw faster than the filter can deliver? All will be rail mounted nearest the the tank if it matters. Never done this type of setup before so pardon the ignorance. Last edited by Dynomutt; 06-17-2010 at 01:20 PM. |
06-17-2010, 08:07 PM | #2 |
Re: Canister filter and electric pump
Good question ill give you a Bump
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
06-17-2010, 09:33 PM | #3 |
Filter before pump and as close to fuel sorce as possible because electric pumps are designed to push where as mechanical pumps pull. So mount filter within 12" of fuel outlet and pump there after. Plus electric pumps are noisy so youll want it twards the back anyway.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
06-17-2010, 09:34 PM | #4 |
The pump instructions should tell you what you need. With an electric pump there is usually a pre and post filter. What pump is it?
Are you using this with a stock tank? If so what tank is it? Most electric pumps like to be gravity fed.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
06-17-2010, 11:10 PM | #5 | |
The tank is custom built but it's not gravity fed. The bung is on the top of the tank with a pickup tube. I understand the concept and why, but that doesn't explain the GPH differences. Seems to me that both units should have the same GPH, or, the unit farthest from the tank should have the lower GPH. Maybe I'm missing something in the numbers or the equipment I'm looking at. Last edited by Dynomutt; 06-17-2010 at 11:19 PM. |
06-18-2010, 12:54 AM | #6 |
most pumps list free flow gph. no filter restriction.
do not run nylon sock filter on in-tank pump pickup. the pump needs to be gravity fed, as in siphon. as long as the pump is mounted as low or lower than bottom of tank, you're good to go. a blue is NOISY, go w/ an in-tank pump is possible. which is why i have an Aeromotive fuel cell/ pump is in the works for the 68 a lot quieter. also run a bypass style reg. it's better. you need a 100 micron mesh filter b4 pump, but after? well if you have FI sure, but I've never seen the point in post-pump filter. you shouldn't be gettin crap in the line between pump and carb. i've not had a problem w/o a post pump filter in my burban.
http://www.cardomain.com/id/Schralper Last edited by Schralper; 06-18-2010 at 12:56 AM. |
06-18-2010, 09:59 AM | #7 |
The blue pump is noisy. I would have to recommend an Aeromotive pump and putting it in the tank (if possible like Schralper suggested) would be a better idea since you have the pickup on top of the tank. Aeromotive has the 11106 which is submersible, but $300, awesome pump though worked great for me. They also have the 11219 which is an internally regulated (7 psi) pump for carb'd engines so you don't have to worry about a regulator or a return line.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time Last edited by Wild83C10; 06-18-2010 at 10:00 AM. |
06-18-2010, 07:16 PM | #8 |
Thanks for the input. I don't really have the option to put the pump in the tank. It's just a pickup tube with a 3/8" bung on the top of the tank.
I'm still doing some more research to figure out what I need to do for my application. It's not a race truck by any means but I do want to do what's best for function and perfomance. I'll be right around 500hp (carb'd) so I may just go mechanical. |
06-18-2010, 08:15 PM | #9 |
The other thing to remember is the blue pump flows 110gph free flow at 14psi. You cant run at 14psi with a carb engine anyhow. The regulator is going to reduce flow more than any filter will by cutting pressure in half. A mechanical pump can feed the engine just fine. If you want an electric pump you can go that way but an edelbrock or holley mechanical pump will take care of your needs as well.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
06-18-2010, 08:31 PM | #10 |
I'd recommend a Mallory 110 pump over the Holley Blue. It's quiet when used with a return style regulator and you can adjust the flow of the pump(at the pump)...not sure if you can with the Holley. Sometimes I couldn't even tell it was on. I used a 100micron filter before the pump and one of those cheap chrome filters between the regulator and carb. I used one of those Summit brand inline filters(SUM-230116-B).
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 06-18-2010 at 08:32 PM. |
06-19-2010, 12:05 AM | #11 | |
check this http://www.centuryperformance.com/fu...e-spg-140.html
http://www.cardomain.com/id/Schralper |
06-20-2010, 12:33 PM | #12 |
Thanks for the link Schralper. Some pretty good info in there.
