Old 06-17-2010, 08:04 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Rubber load helper. Do you have any?
Old 06-17-2010, 11:22 PM   #2
Captainfab
60-66 Nut
Re: Rubber load helper. Do you have any?
I know this isn't OEM stuff, but you could fabricate the mount and use a rubber bumper from these guys.
http://timbren.com/
Old 06-18-2010, 05:42 AM   #3
aerotruk63
aerotruk63's Avatar
Contacted Timbren during the winter, they supplied the rubber to GM but not the bracket.
Old 06-18-2010, 06:26 AM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
next time I am at kellys I will look to see if there are any, do you need some, or just want to see them on a truck?
coil, or leaf?
Old 06-18-2010, 06:28 AM   #5
jonzcustomshop
1961 crewcab
I think my 65 has something similar to that , but they are a coil, not rubber.
Old 06-18-2010, 06:12 PM   #6
aerotruk63
aerotruk63's Avatar
I would like to have either or both. I would like to measure the sizing of the Timbren, then get a replacement.
When I contacted Timbren they stated that the rear kit for the K10, would be GMRP30 model and that there should be some spacing. The stock front of the K10 uses the same snubber as the stock rear C10 coil spring, therefore I assume GMRC10A. Timbren says that the front should be in contact at all times.
Old 06-18-2010, 10:37 PM   #7
jonzcustomshop
1961 crewcab
here is what is on my 65, dosen't look like I am using them, I can't see any spot where they have touched the frame
my gmc 3/4 has the extra spring pack like the pic on the top right.
Old 06-19-2010, 12:11 AM   #8
rendus
rendus's Avatar
I have a set of these on mine:
rendus is offline   Reply With Quote
Old 06-19-2010, 05:36 AM   #9
aerotruk63
aerotruk63's Avatar
rendus has the optional helper leaf springs. jonzcustomshop those must be aftermarket.
Old 06-19-2010, 08:07 AM   #10
rendus
rendus's Avatar
Sweet, thanks for the info...
I bet my special spring lubricant is loooooong gone!
