06-18-2010, 01:30 PM | #1 |
Enthusiast
Electric Fans
So what's everybody recommend out there for Electric Fans, goin' into my 454 meant for towin'.
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
06-18-2010, 08:59 PM | #2 |
Re: Electric Fans
Spal with a thermostatic controller.
06-19-2010, 07:02 PM | #3 |
Parts and more parts
Re: Electric Fans
I would recommend the dual 11" SPAL fan set and a fan controller/ extra relay set, from them to run the fans. The fans are capable of moving some serious air across the radiator and their FAN PWM will run them in either slow or fast speed as needed to get the job done. I have two of these setups in my trucks and we have not had any overheating issues with them.
Frank |
06-19-2010, 07:19 PM | #4 |
GM Addicted
Re: Electric Fans
Is it better to have a pusher or a puller set any links on fans i want to put electrics on my truck soon.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
06-19-2010, 07:30 PM | #5 |
Badass
Re: Electric Fans
what about stock fans from like a jeep or somthing? isnt there any good stock ones out there?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
06-19-2010, 07:46 PM | #6 |
BAD BOW-Silverado XST
Re: Electric Fans
Mark VIII dual speeds fans. You can run low and high independantly.
06-19-2010, 07:53 PM | #7 |
Re: Electric Fans
it's also 18in, one of the bigest fans u can get.
"Myths and legends die hard in America. We love them for the extra dimension they provide, the illusion of near-infinite possibility to erase the narrow confines of most men's reality. Weird heroes and mould-breaking champions exist as living proof to those who need it that the tyranny of 'the rat race' is not yet final." Hunter S THompson |
06-19-2010, 10:09 PM | #8 |
GM Addicted
Re: Electric Fans
are they dual fans though?
06-19-2010, 10:14 PM | #9 |
Re: Electric Fans
A puller fan is more efficient, than a pusher type.
Frank |
06-19-2010, 10:21 PM | #10 |
GM Addicted
Re: Electric Fans
okay ive been looking at some but some of the ones i see are very pricey, im trying to get dual pullers.
06-20-2010, 12:23 AM | #11 |
Re: Electric Fans
06-20-2010, 03:48 AM | #12 | |
haha, ford guys...
Re: Electric Fans
personal advise: wire a over-ride on/off switch in cab!!!! (just incase) Last edited by spinem; 06-20-2010 at 03:50 AM. |
06-20-2010, 09:49 AM | #13 |
Re: Electric Fans
My question would be: What do you call expensive? A good set of fans that work or a new engine for the one that you just smoked?
It is amazing what people will do to their vehicles. They will spend serious money on the engine, wheels, or even the stereo, but when it comes to a good set of fans--they skrimp on the cost. My observation (and I just saw this on the Power Tour, this year) There were some really nice cars with some good HP under their hoods---SITTING along side the road with green coming out from under the hood. I am running the SPAL dual 11" fans (2850 CFM each) on two of my trucks and I have another set in the basement for the project that I am building out of my 68 SWB. I realize that their cost is around $300.00, but it is worth it, because I don't plan on sitting beside the road. My 84 has a storked 385 engine and it made it the whole Power Tour trip without ever getting above 210 degrees. That includes mountains, hills, short back country roads with a lot of stop lights and to top it off the hot humid area around Mobile, Alabama. Summit racing sells the SPAL fans under the "Be Cool" name and these guys have packages that a person can buy on their website. Just some input for the process. http://www.summitracing.com/parts/BCI-75007/
Frank |
06-20-2010, 11:06 AM | #14 |
Still plays with trucks
Re: Electric Fans
There is a thread in the 67-72 area about retrofitting a newer Jeep 19" fan into the fan shroud of one of our trucks. It fit really nice and the shroud only needed minor mods to make it fit. I just can't find the link. I have it bookmarked but only at work.
The fan blade & motor setup they gave the part number for was used in a recall for some 2000-ish Cherokee and was only around $60. If you have a good factory shroud this is the way to go. The late 4th gen Camaro's have a dual fan setup that fits our radiators pretty well too if you don't have a shroud. Not sure on the exact year but 2000-up is thrown around a lot.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-20-2010, 01:26 PM | #15 |
Re: Electric Fans
The biggest advice I can add is no matter which route you take, please also install some sort of temperature control for the electric fan. You do not want the fans running all the time as during freeway speeds the running fan will actually block more air through the radiator than it will move. To further add to my previous post, I ran a universal Aluminum radiator with a single 12" Spal puller fan with a simple controller that just had a probe that pressed in between the radiator fins with no shroud on my 500 caddy swapped C10 with zero issues and that truck was driven all over the place and driven hard. The cooling is one area as others have mentioned to not skimp on.
06-20-2010, 04:40 PM | #16 |
Enthusiast
Re: Electric Fans
So far it appears that the Mark VIII and Spal are the top choices, so I'll take your guys' word on it (i also read up on the links posted above). I'll have to run a price check at my local junkyard and see if they have any Mark VIIIs, and what they want for it. If it's too much then I'll concider going Spal. As for the controller's, i believe I'll stick with Spal, but should i go with the 185 or the 195?
06-20-2010, 06:44 PM | #18 |
Re: Electric Fans
There are many temperature controllers on the maraket. Some have probes that insert into the coolant system somewhere. Others will have a probe that inserts into the fins of the radiator, or into the radiator hose connection at the raditor. There are some that actuate off of the installed temperature sensors on the engine.
Below are listed some outlets for fan controllers. I am presently using the SPAL units in my trucks, but there are others that are just as good. You want one that is prgrammable, Waterproof, and heavy duty for the fan relays. If you run two fans, you want an extra relay to control the fan. If you want to save on that, go to a junk yard and pull a couple relays from the mid 80s trucks that they used on their heater controls. They work real well and do NOT fail in ahigh temp atmosphere. many small relays will just fail open when they get hot. http://www.spalusa.com/store/main.as...tem=FAN-PWM-V3 http://www.centechwire.com/catalog/c...ncontrols.html http://www.summitracing.com/search/?...ntroller&dds=1
Frank |
06-20-2010, 07:14 PM | #19 |
Re: Electric Fans
"The FAN-PWM-V3 is not intended for use with fans that draw more current than 30amps continuously. This includes (but not limited to) SPAL extreme performance fans, Ford Taurus fans and Mark VIII fans."
Not even controllers can keep up with high CFM fans!! The use of relay is basically mandatory. |
06-20-2010, 07:30 PM | #20 | |
GM Addicted
Re: Electric Fans
06-20-2010, 08:26 PM | #21 | |
Re: Electric Fans
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
