View Poll Results: where do you put your temperature sender probe.
probe in T-stat housing 3 10.34%
probe in block 26 89.66%
Voters: 29. You may not vote on this poll
Old 06-19-2010, 11:26 AM   #1
lovnthe70
lovnthe70's Avatar
Temp sender location
Hey guys, where do you perfer to have your temp sender?? In your block or your thermostat housing?? I currently have mine in my block and a mechanic i was talking to said i need to move it to my t-stat housing?. Thats where i used to have it, but it seemed to me i would want to know the temp inside my block. Also how much of a temp difference is there between the 2??
and sorry if the poll dosent work, ive never done one and thought i would try!!
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 06-19-2010, 11:37 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Temp sender location
I think it works, I just voted and it showed up in the poll.
I figure if GM thought it should be in the block that is where I put it. I know some newer cars and trucks also had it in the water neck, but usually that was part of the smog equipment.
I guess it would not hurt to run one in each place if a person wants to know what the temperature is in both places.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-19-2010, 11:56 AM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
My thoughts are in the block. Like you I tend to wonder about the effectiveness of it in the thermostat housing. The thermostat remains closed to the water in the engine untill it heats up enough to flush the hot water out of the engine. Then the water pump replace the hot water with the cooler water from the radiator via the bottom nipple of the radiator. What closes the thermostat is after the engine fills with the cooled water it starts running back into the top of the radiator, cooling the thermostat, witch then closes it. So it makes sence that the teprature of the water in the thermostat housing doesn't reflect the temprature of the water in the block. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-19-2010, 11:57 AM   #4
A69C10
temp diff has been around 10 to 20 degress off as engine is hotter on sbc 355
A69C10 is offline   Reply With Quote
Old 06-19-2010, 12:45 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Mine is in the drivers side cylinder head. Stock location.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-19-2010, 01:21 PM   #6
lovnthe70
lovnthe70's Avatar
so since i have my sender in my block.....and it is approx 10-20 degs hotter there, is a temperature of 210-220 alright? or should i still be around 190-200?
1970 GMC- 454
Old 06-19-2010, 01:29 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
210-220 is a little too warm. Mine runs around 190-195.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-19-2010, 03:26 PM   #8
raycow
Intake would be my first choice, since that was the normal location for a long time. Second choice would be the head. I have never seen one in the block.
Ray
raycow is offline   Reply With Quote
Old 06-20-2010, 12:26 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the head is the stock location on all V 8 gas motors in these trucks.
I would rather know if the engine was overheating, verses the temp of the coolant on the cool side of a stuck t-stat... but that's just me.
Old 06-20-2010, 03:49 AM   #10
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I think the head is a more accurate measure of the internal engine temp, so that is where mine is.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-20-2010, 11:46 AM   #11
LockDoc
The Older Generation
LockDoc's Avatar
I can't verify this as correct but a mechanic friend told me once that the best place is as close to cylinder #8 as possible as this is the warmest area in the engine. Just throwin' this out for discussion.
LockDoc
Leon
Old 06-20-2010, 12:11 PM   #12
OJ1988
Just a car guy
OJ1988's Avatar
Drivers side head for me. Temp switch for rad fan is next to the thermostat on my truck.
Most gm products I have delt with have had it here, or moreso in the same port on the pass head which then, as previously suggested , right next to the #8 cylinder.
That would make sense as it should be hottest. Also, makes it convenient for wiring as it can join up with starter wires, heater control, coil, and any other accessory wires, you know gm considered that for easy assembly.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 06-20-2010, 12:46 PM   #13
GASoline71
GASoline71's Avatar
I have had a '67 Chevy C10, a '71 ElCamino SS, a '79 GMC K25, and now my '72 GMC C1500. All have had the sending unit in the forward hole in the cylinder head between #1 and #3 cylinders in SBC's. Factory wire harnesses went there too...
Even when I ran Autometer gauges in my Elky, I ran the sending unit in the same spot. Just to keep it fairly "original" looking.
Gary
Old 06-20-2010, 01:47 PM   #14
cdowns
cdowns's Avatar
i think the head is best// block i believe can suffer more heat with no damage with the heads suseptible to the damage easier
Old 06-20-2010, 05:11 PM   #15
bigguy69
dazed and confused
bigguy69's Avatar
mine is in the head. between the #6 and#8 cylinders. i prefer the head also
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
