#101 |
Project collector
Re: Project "Jezebel"
Now that I have this completed I need to set the new doors and install the rockers. Then finish welding in the filler for the wiring track on the firewall, weld up a few holes here and there, check the roof for little surprises, then go over the cab to see if everything is welded in completely and the cab will be ready for body work.... Steve
Patch to fill the gap All welded in. Some of my best welding yet I think..... ![]() Cab corner ready to weld. Notice the smaller gaps this time. Cab corner and "B" Pillar extension all welded in. Back view of cab corner.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! |
#102 | ||
Project collector
![]() Steve
#103 |
Project collector
On to some of the custom touches I wanted to do to Jezebel. The cap for the wire gutter. I will wait till I get the cab back on the frame before attaching the door to align the rockers. This way I can attach the fender to make sure all is aligned properly.
I had a dilemma of whether to cap the gutter at a 45deg angle or just a flat cap (90deg). I liked the look of the 45deg cap but compound angles have never been my specialty. I decided to try the 45deg cap anyway and I think it turned out really well thanks to the stretcher and shrinker I borrowed from a buddy. I still have a little welding to do (welder ran out of gas) then more grinding but I really like the way it looks. Here is where I started. I cut this arch off to make the cap appear more uniform. This is the first cap piece. I'm not sure you can see the compound shape that well from this pic. The stretcher and shrinker made the fitment of this pieces a lot better. Not sure If I could have made them without it. The first couple cap pieces tacked into place. The fit was really good if I do say so my self. At least for my work that is.... ![]() And the drivers side.
#104 |
Project collector
Some final pics of the cap.
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! Last edited by sgaylord; 07-29-2010 at 05:45 PM. |
#105 |
VA72C10
![]() Join Date: Mar 2008
looking good! I was very pleased with how the cap came out on my cab as well...think the 45 degree angle really sets it off. and you're right....the shrinker/stretcher was a mandatory tool...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#106 |
![]() Join Date: Mar 2004
Nice work on the cap!
#107 |
That does look really good. I'll be over to have you fit me some caps as soon as I complete my firewall patching
#108 |
Project collector
Getting to the end of the rust finally. I never thought the day would come where I could start thinking about where I need to go from here...
Dr drip rail needed some attention at the bottom. Not too bad huh? Well be careful of what lurks behinds the bubbles in the paint! Rust, filler and another old school repair that someone brazed. Wouldn't have been bad if they would have brazed it completely closed. Left it open for moisture to enter through the filler. Not too hard to fix though. Cut out a 3"x1/2" section and welded in new metal. Still needs a little shaping and a little more grinding to smooth it out. One of only two small holes I found in the roof. I was glad not to find more considering the history I have had with the little artifacts (rust repairs) I have found in this gem ![]() This is the only other rust spot in the roof.
#109 |
VA72C10
almost done!!!!......with the rust
#110 |
Project collector
I still have to get the completed pics of the Pass drip rail but it's just a mirror image of the Dr side.
2nd rust spot on roof fixed. Just above the windshield Fix above Dr door More sneaky little rust. Pass drip rail. The rust in this pic is not as bad as it looks. Just surface rust that came off quickly with a wire brush.
#111 |
![]() Join Date: Apr 2005
Looks good Steve. Hopefully you (and I,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#112 | ||
Project collector
Steve
69 CST-10 SWB (disguised as a 67) 383/700r4 Jezebel Jezebel 3.0 NEW!!! 2020 GMC 3500 Denali Duramax 2016 Harley Street Glide CVO Roll Tide! Last edited by sgaylord; 06-25-2010 at 03:12 PM. Reason: Grammer |
#113 |
Wow, thanks for commenting on my post so I could find yours
#114 |
finally checked out this build... man your a monster!! Great work, keep it up.
Juan
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#115 |
Still Learning
Great work on the firewall smoothing and rust repair! Keep it up
#116 |
wow iSuscribed
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
#117 |
Looks good, can't belive thats the same truck. Mine's next. LOL
'72 Nova '71 C10 '63 VW Beetle ![]() ...............................____ .................________-|___\____ ..;.;;.:;:;.,;.|__(O)___|____/_(O)| _______________________________________ |
#118 |
dazed and confused
doin a great job!!
members met: redbaron69, billsbowtie,nc67 |
#119 |
Project collector
I have been slacking a while uploading pics and providing updates. Lots of progress to talk about.
There was a small rust spot in the Dr. side windshield channel. Not too bad to fix. Just cut the bad area out and form a replacement.
#120 |
Project collector
Next was a small patch next to the pass side cab corner. This was a little tricky getting the profile correct but with a little hand work I think it came out pretty good.
#121 |
Project collector
Next on to the pass outer rocker. This went fairly well. A few small tweaks here and there. A pie cut here and there and it fits pretty good now.
#122 |
Project collector
Next was the Dr. side. The profile of the cab corner did not match the lower door. I had to cut a relief cut and pull the skin out to match the profile of the door. Not too tough, just had to fiddle with it a little to get it to aligned.
#123 |
Project collector
Now on to the Dr outer rocker. The lower section where it meets up to the cab corner was a little short. I cut the edge off so I could maintain the profile and added a 1/4" section to fill the gap. Came out looking really good.
There is quite a bit more progress that I will post probably tomorrow.
#124 |
Wow, this is great! For my sake, I hope my panels don't take as much work to line up. I'll be screwed
#125 |
Looking good
http://www.tandscustomcars.com/ ![]() IT"S GOT A ROOF NOW WHOO HOO!!!! ![]() 65 GTO Build (If you wanna check it out) ![]() |
