Old 06-21-2010, 02:53 PM   #1
jyaughn
jyaughn's Avatar
rear end
will the rear end out of 77 gmc parts truck work on my 62?
jyaughn is offline   Reply With Quote
Old 06-21-2010, 04:21 PM   #2
raycow
Re: rear end
It won't bolt in. You can use it if you weld on the mounts for the trailing arms and panhard bar. Also, it is about 1-1/2" wider than the stock 62 rear, but normally that won't be a problem.
Ray
raycow is offline   Reply With Quote
Old 06-21-2010, 10:50 PM   #3
jyaughn
jyaughn's Avatar
Re: rear end
so it being a little wider wont hurt anything?
Old 06-22-2010, 02:06 AM   #4
raycow
Re: rear end
I have never had a problem with any tires I could get on the stock wheels. It's a potential problem only if you run wide wheels/tires and are lowered enough that the tires can rub the fenders. Normally, you can avoid interference with aftermarket wheels by choosing your backspacing carefully.
Ray
Old 06-22-2010, 09:13 AM   #5
jyaughn
jyaughn's Avatar
Re: rear end
i wanna run 17 inch wheels with a ten inch wide tire and the truck will be lowered 5 inches in the back. you think i will run into any problems?
Old 06-22-2010, 10:56 AM   #6
19GMC63
19GMC63's Avatar
Re: rear end
fleetside or stepside?
19GMC63 is offline   Reply With Quote
Old 06-22-2010, 04:25 PM   #7
jyaughn
jyaughn's Avatar
Re: rear end
step
Old 06-23-2010, 04:35 PM   #8
Russ65C10
Russ65C10's Avatar
Re: rear end
You're going to be pushing it trying to fit a 10" in a stepside I believe. G60's 265/60 or 70's are about the widest tires I've been able to fit under mine and its not dropped.
Russ65C10 is offline   Reply With Quote
Old 06-23-2010, 11:10 PM   #9
jyaughn
jyaughn's Avatar
Re: rear end
well i might have to go with a smaller one. im just scared my trucks not gonna hook off the line after im done building my motor
