how do you disassemble a front axle manual locking hub
I have to change some of the wheel studs and therefore remove my rotor. I've never disassembled a four wheel drive hub before. Anyone have any tips, pics would be great too?
New Member
Re: how do you disassemble a front axle manual locking hub
It's pretty easy but you will need a special socket like this one.
"Hooked on Quack"
which you can pick up at pretty much any autozone.
Semper Fi, Kevin ![]() ![]() |
you can find plenty of sites with the instructions. search for dana44 hub install
like this but start at the bottom http://www.keystonekrawlers.com/tech...ub_rebuild.htm
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
found some wheel hub sockets but theres a few different sizes, does anyone know what size to use for a 78 gm axle? how many foot/pounds of torque for re-installing?
There is only one basic wheel hub socket for GM trucks, it's about 1 7/8" inside the teeth, 2 1/8" round or so...
torque is always a big question... I have read that the initial torque on the inner nut is about 50lbs to seat the bearings, then back it off a little. you'll have to research to be sure..
#7 | |
New Member
what amount of torque do i put on the outer nut? 50 as well and back off a quarter?
#9 | |
No, don't back-off of the outer nut. It is part of the "locking" system, the "adjustment" is with the inner nut only.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
So torque it to 50lbs as well and leave it?
Local Redneck Authority
I think it's one of those things you'll figure out when you get there. If it's too tight the wheel won't spin, if it's too loose it'll feel like the bearing is going out. You gotta feel it.
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
#12 | |
![]() Join Date: Feb 2007
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
note: set up the bearing on just the first nut and don't worry about the torque the first nut is there for fine tuning, then torque the second(outer) to 55 ft lbs before finishing spin the rotor about 10 or so times forwards and then a couple times backward then recheck torque again on the outer only if torque is 50-60lbs then your fine if its at 45-50 then retorque if its outside of 45-60 then re setup the bearing and try again
1991 V3500 350TBI/4l80/205 D60/14bff - Crew long 1987 IrocZ-28 525 horse/567 Lb Tq 383 1976 K30 on 39.5s One wheel drive thanks to a np203 ![]() and some K5's lol |
