06-22-2010, 06:38 PM | #1 |
Can anybody with a manual transmission check?
Does the swivel on the clutch adjustment rod go in the lowest hole of the bell crank ("Z bar") or does it go on the second hole up, which has a raised boss and slightly smaller diameter opening.?
I am working on the clutch adjustment on my 83 C20 with SM 465 manual 4 spd. transmission. The clutch keeps going out of adjustment. There are two holes on the bottom of the bell crank (Z bar). My existing setup has the threaded "lower pushrod" swivel installed on the lowest (furthest down) hole. This results in some "slop" in the swivel which may account for the frequent loss of adjustment. The other hole (higher up) looks like a better match for the stud on the swivel, but it would put the adjustment rod at a sharper angle to the clutch fork. Any ideas? Thanks. |
06-23-2010, 05:35 PM | #2 |
Re: Can anybody with a manual transmission check?
on my 76 the clutch adjustment bar is on the lower hole of the z-bar.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
06-23-2010, 07:23 PM | #3 |
Thanks BigRed. I wonder what the other hole is for? I have seen it described as a "gage" hole elsewhere.
06-24-2010, 09:13 AM | #4 |
On a budget like Fred Sanford
The other hole should be for a return spring, one end goes there and the other on the frame.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
06-24-2010, 10:47 AM | #5 |
My return spring hooks to a bracket on the clutch fork. Is that an incorrect setup?
06-24-2010, 12:52 PM | #6 |
It'll work, I've seen them both ways. Some have one spring going from the frame to the fork, others have a spring going from the frame to the z-bar and another from the fork to the z-bar.
06-24-2010, 03:23 PM | #7 |
Grab yourself a copy of the catalog from Classic Parts. They have a complete diagram in there with all of the parts numbered. This is the diagram I will be following when I order extra parts to complete my swap
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
06-24-2010, 05:52 PM | #8 |
Thanks. I am looking at the Classic Parts diagram. Nothing appears to go in that second (highest up) hole in the end of the bell crank. Is that a wave washer between the cotter pin and the flat washer at the end of the bell crank at the swivel attachment? (The catalog just says #22, which is for the whole kit.) Is it: cotter pin, wave washer, flat washer, bell crank OR cotter pin flat washer, wave washer, bell crank? I have no wave washer - maybe that is my problem.
06-24-2010, 06:51 PM | #9 |
I also see two springs in the Classic Parts diagram: clutch pedal return spring and clutch fork pullback spring. I have the clutch fork pullback spring, but I don't see where the clutch pedal return spring goes. Do you manual transmission guys have two springs? If so, where does the clutch pedal return spring connect. I can't quite make out the attachment points on the drawing. The drawing makes it look like both springs connect to the clutch fork - which can't be right. Thanks.
06-24-2010, 09:30 PM | #10 |
my 76 only has the clutch pedal return spring, and its up underneath the dash on the clutch pedal. i didnt know there was supposed to be a spring on the clutch fork...
06-25-2010, 12:29 AM | #11 |
Maybe you get one or the other, not both. When I disconnected the spring to the clutch fork the clutch pedal dropped to the floor. I disconnected the spring to install a new clutch fork boot. I don't know why you would need two springs in about the same location, as appears to be the case on the Classic Parts drawing.
06-25-2010, 07:49 AM | #12 | |
06-25-2010, 08:42 AM | #13 | |
Still plays with trucks
I can take some pics later today if needed.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-25-2010, 11:07 AM | #14 |
Yes, please take pictures and post them. I have the SM465 with the spring on clutch fork bracket to frame, but that appears to be all. Since my clutch keeps going out of adjustment, maybe another spring would help. Also, the correct arrangement of the attachment hardware for the "lower pushrod assembly" (or adjustment rod) would be nice to know: i.e. cotter pin, flat washer, wave washer, bell crank - or whatever the correct sequence is.
Perhaps Keith Seymore can post on this, since he was there in the plant when these trucks were built, and he has a 100% correct specimen to look at. |
