Old 06-24-2010, 04:00 PM   #1
FL71C10
454 going into 71 C10
OK, you gas hogs have convinced me to put a 454 in my 71 SWB stepside. Now I need help. What will I need to make it fit? The motor I think I am going to get is currently in a 1990 motor home. I think I'd like to keep the stock exhaust manifolds if possible. Will that make it easier? I guess I need to get engine stands to bolt the motor mounts to. I saw somewhere on here that someone bought some tubular ones that they wer ehappy with. The trans is a turbo 400 so my automatic crossmemember should fit, right? What about power brakes and power steering pump and brakcet clearances. Will I need a special smaller booster to run power brakes?
I'm guessing I should get the driveshaft from the motor home but will have to modify it. I don't know about the radiator fan or any of those things yet.
Any thoughts or suggestions?
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 06-24-2010, 04:28 PM   #2
capev86
Re: 454 going into 71 C10
i would suggest you use the manifolds from a 67-72 big block truck or get some custom headers that will fit.
i don't know why anyone messes with a turbo 350 or turbo 400 anymore with the price of gas. you can swap a beefed up 200-4r for a t350 and i believe a 700-r4/4l60 for a 400 w/out messing with the driveshaft length.
capev86 is offline   Reply With Quote
Old 06-24-2010, 04:36 PM   #3
mrh33916
Project '67 454
mrh33916's Avatar
I'm running the big brake booster with short valve covers with no problems, my powersteering pump clears the frame ok.
You will need a 4 row radiator with the big block.
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 06-24-2010, 04:41 PM   #4
FL71C10
mrh33916:
What engine stands/brackets did you use?
Old 06-24-2010, 04:42 PM   #5
FL71C10
Is a 454 a "Tall Deck" motor? If so, will that cause clearance problems?
Old 06-24-2010, 04:45 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
There are not any 454 tall deck engines. Only 366 and 427 tall decks. If your intake has a thermostat with 2 thermostats then it is a tall deck. If it only has a single thermostat then it is just a short deck.
Ryan
1969 Chevy milk truck
Old 06-24-2010, 04:46 PM   #7
mrh33916
Project '67 454
mrh33916's Avatar
Originally Posted by FL71C10 View Post
mrh33916:
73-87 clamshells for engine mounts,
'86 long waterpump and brackets for access.
75 Datsun 280ZZ430
Old 06-24-2010, 04:49 PM   #8
FL71C10
Did you have to use different engine stands? I'm hoping I will be able to use all of the accessories and brackets that come on the engine.
Old 06-24-2010, 04:50 PM   #9
FL71C10
Thanks Dieselwrencher.
Old 06-24-2010, 05:28 PM   #10
rollinhard
rollinhard's Avatar
Chevy does make a 454 tall deck block but its a race prep'd gen v bowtie block and if you have one of those youd be stylin
If you can't impress them with your inteligence, dazzle'm with your stupidity
1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe
rollinhard is offline   Reply With Quote
Old 06-24-2010, 05:41 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
When we put a '73 454 out of a C-20 in my '71 lwb stepper we used the motor mounts from the '73. The stock exhaust manifolds would not clear the clutch linkage so we went with headers.
When we mated the engine to the old 4 speed transmission we let the engine settle and drilled new holes for the motor mounts. The firewall clearance was good and so was the fan clutch to radiator.
We used the complete 454 including the water pump, power steering pump and clutch fan. My '71 already had a 3 core radiator and the engine runs real cool. We used the temperature sending unit from the 350 that was in my truck.
We also used the fan shroud from the '73 but had to notch it for crank pulley, power steering pulley and alternator pulley.
Good luck.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-25-2010, 04:23 AM   #12
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
You don't need a special smaller booster to run power brakes? I used a stock one for my 72 454BB Im also running headers and some nice tall valve covers.I am useing 72BigBlock Motormounts though I do not know if the 71Big Block motor mounts and towers will interfear with headers or manifolds or frame. I have heard that 73-87 engine mounts are simular to the 72's and work great.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 06-25-2010, 06:50 AM   #13
cdowns
cdowns's Avatar
1990?? is this a carb or injected motor? does the motor have provision for a fuel pump?// if available get as much stuff as possible from the donor vehicle
Old 06-25-2010, 08:17 AM   #14
FL71C10
It is a carbed engine from a motorhome. Must be one of the last ones without fuel injection.
Old 10-16-2015, 09:33 PM   #15
scoots71
Has anyone tried 73 up headers in 67-72 2wd
scoots71 is offline   Reply With Quote
Old 10-19-2015, 04:45 PM   #16
SeniorVerde
SeniorVerde's Avatar
I have used Headers from a 73-87 (1976 actually) and they worked ok when I was mocking the same 454 in my 71 (transplanted from the '76.
Only bummer is that I don't know who made them or what they were actually meant for.
SeniorVerde is offline   Reply With Quote
Old 10-19-2015, 05:28 PM   #17
scoots71
I see your using the tall valve covers how do they fit ?
Old 10-19-2015, 05:34 PM   #18
SeniorVerde
The valve covers are close but there is clearance. I thought about doing a bit of body work to the firewall, but I'm going to call it good.
Truck got sidelined for a bit while I work on my jeep, so we aren't running yet, but I'm using factory 71 big block mounts and we seem to be OK so far
