Old 04-28-2003, 06:18 PM   #1
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
WTB: Rear lowering coil springs
Hello, looking to buy some cheap rear lowering coil springs (4 in. or more) for my '71 C-10, used ones would work as they're intended for my beater, if anybody has a pair laying around that wants to get rid of please let me know.
Thank you. fatman.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 04-28-2003, 06:22 PM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I hear the GM "A" body springs work fine but I am unsure of how much they drop the rear of the truck. I picked up a set at a swap meet for $10 and am dying to give them a try. I should finish my exhaust this week and then they are going on! I'll let you know...if you can wait.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-29-2003, 10:27 AM   #3
chevy_fatman
Where's my beer?
Sure! let me know how they fit and low they get your truck, if you don't mind.
I appreciate the reply. fatman.
Paul
Old 04-29-2003, 10:44 AM   #4
Frank_Zeller
Frank_Zeller's Avatar
I bought a MOOG coil spring catalog to investage this. Based on info in the book the A body springs are a direct replacement. Looks like they would give 3 to 4 inches of drop. Look on ebay they go for 10-25 dollars. Search "Rear Coil Springs"
link to one pair but they are new
http://cgi.ebay.com/ebaymotors/ws/eB...category=42606
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 04-29-2003, 11:01 AM   #5
chevy_fatman
Where's my beer?
Thanks for the info Frank!, do you also know between what years will fit? Thank you for the link man.
fatman.
Paul
Old 05-27-2003, 12:13 AM   #6
Old Chevy Lover
Old Chevy Lover's Avatar
stllookn - came across this post, and wondered if you ever installed these. Was wondering how much of a drop it gave you..
Keith
70 Chevelle Malibu SS Clone 468/Auto
72 C10 SWB 350/Auto
13 Camaro SS/RS 6.2/Auto
Old Chevy Lover is offline   Reply With Quote
Old 05-27-2003, 01:14 AM   #7
72addict
I put a set on the rear of my 1/2 ton. moog p#5409
1957 Cameo
72addict is offline   Reply With Quote
Old 05-27-2003, 01:35 AM   #8
68 Suburban
68 Suburban's Avatar
So how much of a drop do you figure? Andf how is the ride? Have you driven with any weight in the back? Thanks
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-27-2003, 02:09 AM   #9
72addict
Haven't loaded anything in back. Don't have the truck plated yet either. I'll let you know.
1957 Cameo
Old 05-27-2003, 06:42 AM   #10
70c10
67-72 Addict!
70c10's Avatar
what size are those rims?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-27-2003, 10:44 AM   #11
Old Chevy Lover
did you measure before and after you installed the springs to see how much drop there was?
also, here is a link that has a chart at the bottom that shows the part numbers to different springs of differnt cars if anyone is interested..
http://site18951.dellhost.com/gfiles/g_spring.html
Keith
72 C10 SWB 350/Auto
Old 05-27-2003, 10:56 AM   #12
Old Chevy Lover
Here is another link that has some spring info, and how to figure ride height, load height, etc...
http://www.hotrodbuick.com/springs.html
Keith
72 C10 SWB 350/Auto
Old 05-27-2003, 01:52 PM   #13
Blue68
Blue68's Avatar
Frank_Zeller,
What does the Moog catalog say that the spring rate, load height, and free height for the replacement springs on our trucks? I believe the part numbers are like 6101 and CC603.
Also, any ideas on the rear weights? I'm guessing about 1600lb minus whatever a rear axle weighs, or around a sprung weight of 1300lbs?
And...If you are going to try and grab a specific set of springs from an A-body or G-body in the salvage yard, how do you know what to look for?
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 05-27-2003, 05:45 PM   #14
Frank_Zeller
I will look the info up tonight.
Austin-Texas
Old 05-28-2003, 08:53 AM   #15
Frank_Zeller
The is from the 1996 version of the MOOG Coil spring catalog
Stock 1967-72 rear C10 #6101 or CC603 (comfort coil)
6101 stats 5.5 ID Wire Dia 0.740 load height 8.75 load 1700 rate at load height 382 Free height 13.197 pig tail type 3
5409 is listed as a B skylark 72-71, C Malibu 68-67 Cutlass 1968 P tempest 1967
Stats 5.530 ID wire dia 0.552 ID load height 7.50 load 849 rate load 140 free height 13.53 pig tail type 19
to lower the rear I would get the #5401
Cutlass 69-68
GTO 1969
Lemans 1969
or Shortest spring
5385 5.53 ID 0.58 wire dia 9.0 load height load rate 166 free height 12.6 pig tail type 19
B Skylark 72-67
C Chevelle 72-71
C Malibu 72-71,69-68
P Grand Prix 72-69
Or go out to the junk yard and get some used ones from any of the above listed vehicles or ebay.
Frank
Austin-Texas
Old 05-28-2003, 09:11 AM   #16
Old Chevy Lover
Thanks for the spec's, Frank! On the 5385, I think you left out the load rate at loaded height.
Keith
72 C10 SWB 350/Auto
Old 05-28-2003, 09:21 AM   #17
Frank_Zeller
#5385
5.53 ID
0.58 wire dia
602 load
9.0 load height
load rate 166
free height 12.6
pig tail type 19
#5401
5.53 ID
0.531 wire dia
726 load
7.5 load height
load rate 128
free height 13.159
pig tail type 19
#5409
5.530 ID
0.552 wire dia
849 load
7.50 load height
rate load 140
free height 13.53
pig tail type 19
Stock Spring
#6101
5.5 ID
0.760 wire dia
1700 load
8.75 load height
rate load 382
free height 13.197
pig tail type 3
Think I got it right this time.
Austin-Texas
Old 05-28-2003, 09:27 AM   #18
Old Chevy Lover
Thanks man.. I was looking for that 602 number..
Keith
72 C10 SWB 350/Auto
Old 05-28-2003, 01:35 PM   #19
Blue68
Blue68's Avatar
Ok, now I'm confused. The 6101 load ratings look a lot like front spring ratings. At 1700 per spring, you would have to load 2500 (based on the springs being inside the lever aka trailing arms) pounds at the rear to get it to load height.
And this is twice as much force as any of the other springs listed, yet 72addict's truck isn't sitting on the bump stops. To get to the same loaded force of 1700 pounds, the 5409 spring would be coil bound. The 6102 is I think the front spring for the same truck, and these numbers would make more sense on the front except I'm pretty sure the front springs are much taller than 13 inches, right?
Am I missing something here? I'll admit to not knowing how to calculate for levers, but it would seem that at some point (ideally 3 inches or so lower than stock) the other springs must exhibit similar load force to hold the truck up.
Old 06-02-2003, 09:44 PM   #20
Old Chevy Lover
Hey Frank,
Could I possibly trouble you to find the spec's for CC501 Moog springs in your catalog? I have looked on the web, and can't find them published anywhere.
Keith
72 C10 SWB 350/Auto
Old 06-03-2003, 08:43 AM   #21
Frank_Zeller
CC stands for Variable Rate. The rear CC coils I've seen have a tapered coil winding.
My Catalog does not list the spring details other than application.
CC501 is rear coil for
B Skylark 72-67
C Chevelle 72-71
O Cutlass 72-67
P GTO 71-69
P Grand Prix 72-69
Austin-Texas
Old 06-03-2003, 08:59 AM   #22
Old Chevy Lover
From the applications you listed (these and the earlier ones), it looks like its similiar to the 5385 applications. Being that this is a variable rate spring, looks like it would be better suited for a truck. Thanks for the info, again!!!
Keith
72 C10 SWB 350/Auto
Old 06-12-2003, 11:47 PM   #23
Old Chevy Lover
Installed the Moog CC501 springs on the back of my truck. Gave me a 3 1/4 inch drop when let back down on concrete. Don't know if new coil springs 'settle' any once driven or not.
Keith
72 C10 SWB 350/Auto
Old 06-13-2003, 08:51 AM   #24
Frank_Zeller
Great..........
Austin-Texas
Old 06-13-2003, 01:40 PM   #25
Old Chevy Lover
Thanks again Frank for all your willingness to help and information!
Keith
72 C10 SWB 350/Auto
