Closed Thread
Old 06-20-2010, 12:03 AM   #376
Rat Bastid
Rat Bastid's Avatar
Re: What did you do to your truck today!
ill let the pics do the talking
Rat Bastid is offline
Old 06-20-2010, 12:05 AM   #377
Rat Bastid
Rat Bastid's Avatar
some more
Old 06-21-2010, 10:30 PM   #378
breeh
Recovering 67-72 Addict
breeh's Avatar
Continued to clean, paint, and bolt stuff to the chassis.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline
Old 06-21-2010, 11:00 PM   #379
07SSSC
07SSSC's Avatar
Found out the custom kick panel enclosures I bought from a member probably won't work. So then I decided to get my new carpet layed out so it can try to flatten out. Anyone know where to get grommets for the dimmer switch that'll match?
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline
Old 06-21-2010, 11:04 PM   #380
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
put my front swaybar on for a total of 45$ lol
and started my gas filler for my blazer tank now i gotta adapt 2 1/4 down to 1 1/2..
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 06-21-2010, 11:11 PM   #381
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Drove it home from the mechanic. Now we'll see if the transmission holds up. They couldn't get it to act up at the garage and it was okay for the ride home.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 06-21-2010, 11:56 PM   #382
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Installed a middle matching seat belt from a 69. Thanks to Sharpie72 for coming through so I can take the whole family for a ride
Becoming a premium member where you can buy and sell is a must
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline
Old 06-22-2010, 02:53 AM   #383
Lippyp
English Chevy Owner
Lippyp's Avatar
I finally installed my mini starter and then came to a halt when I realised I had one more wire than I had terminals. Looks like I'll be starting to strip the top end off during the evenings ready to install the new manifold, HEI and loom this weekend.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 06-24-2010, 07:57 PM   #384
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
The other day I replaced all the bulbs all over the truck. Replaced the lenses front and rear. Still trying to find my misplaced NEW sidemarker lenses. Thanks GMCPauls for the lenses! Bought them like 5 years ago!
Today I fixed my FROZEN drivers side window regulator! It was frozen all the way up so I had to deal with all that too! Thanks to Classic Parts!
1. New drivers side window regulator.
2. New matching locks for doors, glove box and ignition!
3. Fixed drivers side door latch control rod. Missing control rod attachment bracket.
4. New stainless steel vent visors.
5. New High/Low beam switch! Now I have high and low beams!
6. Lubricated everything having to do with the doors, latches, etc etc.
Had a fairly productive day seeing that is was almost 100 degrees today!
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline
Old 06-24-2010, 09:37 PM   #385
big_al_71
big_al_71's Avatar
Drove the heck out of it with the "chicks"
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 06-24-2010, 09:43 PM   #386
Hubscrub
Cruzin
Hubscrub's Avatar
sanded on my drivers doorpanel and it would be ok but i glued some fabric and stuff to it a few years ago sooo.....got one done just about, i'm thinking i will make some wood panels to cover sometime one of these days
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 06-24-2010, 11:03 PM   #387
Shyguy
Junior Member
Shyguy's Avatar
I fired up the "Lil Beast", took it out of the garage and drove it around the property just for the heck of it.
The "Lil Beast" is made up so many other years I can not remember them all, it is titled as a '67.
It is a swb with a 250 backed by a granny 4 speed, sure fun to drive.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 06-24-2010, 11:58 PM   #388
07SSSC
07SSSC's Avatar
I sanded the bondo I put over the patch panel for my fuel filler hole then masked it and hit it with some rattle can primer. Then started work on my stereo system, got dark before I got too far.
07SSSC is offline
Old 06-25-2010, 03:41 AM   #389
sinned4me
walked by it and didn't even say hi.
sinned4me is offline
Old 06-27-2010, 07:28 PM   #390
67Slider
67Slider's Avatar
Dropped in the engine, installed new MC and power booster, steering column, ebrake assembly, vents and a list of other little things. A Good day!!!![IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I can't wait to see what I get done tomorrow!! Vacations are awesome!!!!!!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-27-2010, 08:51 PM   #391
SweetandLong68
Your UncleBen
Yippee! Drove mine to work today!!!!
I put it up on my lift and had a little personal time with it! Checked everything over and fixed a few things along the way and found some more things I am going to have to get took care of too! Always right!?
I gave my upper radiator hose a little long life expectancy by making a rub guard for it! It was rubbing on my altenator bracket.
I tightened my fan belt that was squeelin when you got on it. It is better but I am thinking a new belt is in order!
I greased the entire front end and man it needed it!
Aired up the tires they were all sitting on 20psi!
Lubricated the shifter and clutch linkage while I was under there.
Inspected the whole underneath of the truck. Looking really great under there. VERY VERY SOLID! I am very happy with everything.
Also realized I am going to need to replace the spark plug wires. My small block is missing because the wires a crap and grounding out on the exhaust manifold. Not surpised..Just another thing I need to do!
lata
CHRIS
Old 06-27-2010, 08:52 PM   #392
orangek5
orangek5's Avatar
Started replacing the rot above the windsheild.
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline
Old 06-28-2010, 12:06 AM   #393
crapy67
White wall terror
crapy67's Avatar
Did a 3/5 drop
crapy67 is offline
Old 06-28-2010, 12:12 AM   #394
vectorit
What?
vectorit's Avatar
Cut out four new replacement panels for my headliner in the burb.
Then spent a day and a half trying to make them fit right...
Still not done, since the heat of the day wiped me out and I was making to many mistakes. So I cleaned up, and planned to pick up where I left off real soon.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 06-28-2010, 12:19 AM   #395
red71c10
The Red Menace
red71c10's Avatar
New floor mat, seat cover and front marker lights. My passenger door mirror is on order and should be here in a few days.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline
Old 06-28-2010, 12:25 AM   #396
07SSSC
07SSSC's Avatar
Just about got my stereo ready for the final install. Made pods to mount my 5.25" speakers to my kickpanels Friday and bondoed them. Sanded and primered then painted them yesterday. Then made some tweeter mounts out of stainless and mounted them to the bottom of the dash. Kinda looks like a gauge mount but it works. Also made mounts for the crossovers to hide them under the dash. Ran some of the wiring, just gotta get some screws to mount the 5.25"s and the amp then I can start wiring. Can't wait to start rockin out
So close to the end of this phase that I can't wait, I've been thrashing every night for who knows how many weeks. I'm sore and worn out but it's all worth it, I hope lol. Love this thread btw.
07SSSC is offline
Old 06-28-2010, 01:01 AM   #397
Pont406
I was able to park my truck in the garage after major clean up. Now it's a pita to do anything but atleast it's inside away from elements.
Pont406 is offline
Old 06-28-2010, 09:00 AM   #398
crapy67
White wall terror
crapy67's Avatar
Hey PONT406 I love your Ventura that a pretty rare car around these parts, I have a 71 Nova and Have always wanted a Ventura.
crapy67 is offline
Old 06-28-2010, 10:40 AM   #399
67Slider
67Slider's Avatar
Got the radiator support, radiator and new hoses installed. Waiting on gaskets for the heater core to finish the engine compartment.
[IMG][/IMG]
[IMG][/IMG]
I hear ya about the garage space. I forgot how heavy the truck is with the motor back in. It is a tough push up the driveway and back intot he garage!!!!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-28-2010, 12:48 PM   #400
Cole Trickle
C-10 Club Member
Changed the tranny fluid and cleaned it up a tad.
Changed the rearend oil and cleaned/painted the diff cover while it was apart. (So far it looks like I fisxed the leaking rearend)
Took a nice cruise with the family to the beach.
Closed Thread
