Old 06-27-2010, 09:00 PM   #1
Marc33
Marc33's Avatar
new 454 in my 71, backfiring issues
I put a new motor in my old truck, mild 454. with a cam, new edelbrock 750 carb, new performer intake, thorley tri y's etc. HEI ignition
I am taking it tomorrow for the exhaust, currently running open headers.
Under load, the motor backfires. At cruzing speed, like 35-40 it is smooth. Idle in neutral smooth, revving at idle smooth. Once I get moving smooth.
The timing is set to 4 degrees btdc and I think I am good on the vacuum side of things. Any advice would be welcome.
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1971 GMC Sierra Grande 2500 2wd
1972 Chevrolet K5 Blazer
1966 Chevrolet C20
1972 Chevy Suburban 4x4 1500
1956 Chevy 150 2 door post
1956 Chevy 2 door post bel air
1968 Chevrolet C20
1958 Ford Thunderbird
1968 4x4 Suburban 1/2 ton
Marc33 is offline   Reply With Quote
Old 06-27-2010, 09:08 PM   #2
BigCarl
Re: new 454 in my 71, backfiring issues
What color is the smoke coming out? Are you backfiring through the carb too? Have you tuned the carb or is it dropped on out of the box?
I had a hell of a time last week with my truck. I was backfiring through both holes.
It turns out for me it was a lean mixture.
Try putting on a stock air cleaner (reducing the amount of air going into the engine) Or you can throw some painters tape around your air cleaner if its open. Try running your truck then. If it runs better, your air/fuel mixture is too lean.
BigCarl is offline   Reply With Quote
Old 06-27-2010, 09:18 PM   #3
Newtz67
Newtz67's Avatar
Try advancing a little more. Try 10 degrees advanced. I'm running my 454 at 13 degrees advanced.
Newtz67 is offline   Reply With Quote
Old 06-27-2010, 09:28 PM   #4
junkman
I'd give it a bit more timing too, and double check valves. Is the motor new? If not, I've had a couple that acted like that, wore down cam lobe, bent pushrod, things to look for too.
junkman is offline   Reply With Quote
Old 06-27-2010, 09:37 PM   #5
68 c10 ls2
68 c10 ls2's Avatar
This may sound dumb but check your firing order. If you have one in the wrong spot it could to that to. It happened to me when i had the old motor in my truck. It ran awsome at idle and crusing but under load i had a backfire.
68 c10 ls2 is offline   Reply With Quote
Old 06-27-2010, 10:08 PM   #6
junkyardjohn
junkyardjohn's Avatar
That timming or firing order issue has got me a bunch of times, & I'm no newbee to the world of old chevy small & big blocks. I ussually put the tranny either in reverse or drive (doesn't really matter witch) stand on the brakes, & excelerate. (trying to see how it acts under a load) If it bogs & backfires thru the carb, it's usually a fireing issue. Either a plug wire or maybe I stabbed the dist. one tooth off. First i check the wires (it's easy & I'm basically a lazy sh!t) & then I'll pull # 1 up to tdc & restab the dist. I've put on about 50 new edelbrock carbs & 99 times out of 100 they work just fine right out of the box. Don't start second guessing yourself & trying to adjust things you think are probably o-k. This old man I worked with as a kid always used to say... when you hear hoofbeats.... don't look around expecting to see unicorns. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-27-2010, 10:24 PM   #7
Newtz67
Newtz67's Avatar
I just want to agree with the carb advice. I use these carbs (if it's the performer series) and love the fact that they're so simple, and good to go outa the box. I also admire your honesty about being a lazy sh!t! I'm also lazy, just afraid to say it out loud. I wanna be just like you when I grow up!
Old 06-27-2010, 10:25 PM   #8
Marc33
Marc33's Avatar
well, I was looking for a less obvious reason for this issue, but John reminded me to double check the obvious. I had the dist in and out so much over the last few days that wires 5 and 7 got switched accidentally.
All better I think, I will test drive her tomorrow morning. Getting a little late to test drive the big block with open headers around here.
Thanks John,68 c10 ls2, and everyone else too!
Current stable:
1970 K5 Blazer 4x4
1972 K5 Blazer 4x4
SOLD:
1966 Chevrolet C20
1968 Chevrolet C20
Old 06-27-2010, 10:26 PM   #9
Newtz67
Newtz67's Avatar
Right on!
Old 06-27-2010, 11:00 PM   #10
junkyardjohn
Originally Posted by newtz67 View Post
i just want to agree with the carb advice. I use these carbs (if it's the performer series) and love the fact that they're so simple, and good to go outa the box. I also admire your honesty about being a lazy sh!t! I'm also lazy, just afraid to say it out loud. I wanna be just like you when i grow up!
thanks.. Thats probably the ultiment compliment.... Lazy folks seem to think & come up with the simplelist & fasted solutions to a problem, instead of just jumping in & doing stuff that winds up compounding a problem you already had. Sometimes thats a good thing. john
junkyardjohn
DON'T RENT U-HAUL
