![]() Join Date: Apr 2010
For those with Wood Beds....
For those with wood beds, I am wondering what you have done to rebuild or otherwise renew things out back. What I am looking to do is renew my bed while maintaing some functionality. I would like to use the truck for trips to and from Lowes.Home Depot, Sears, etc. I can't imagine owning a truck without using it!
So let us all know what you have done! Thanks!
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
![]() Join Date: Jul 2007
Re: For those with Wood Beds....
I have an ole longhorn that is really nice and original and I still use it to haul dirt and homedepot loot around so I know how ya feel. If there is just some wood broken through you could have a couple options.
1. replace all the wood and reuse the original strips and get new bolts (for easyness sake). 2. replace just the pieces that are broken and bolts as needed, to keep holes from dropping your homedepot loot on the road. (I have the dimension diagram for each piece for a wood floor somewhere, but there are threads that have that info in them here SOMEWHERE) 3. Get a ~16 Ga piece of metal to cover the rear of the bed where the holes are and it gets the most abuse. Just use some small bolts and washers to secure it after its cut. ( I have done this in the past to a 72 lwb and it worked great) Just a few ideas for ya.
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
#3 | |
I need new strips as well as the angle strips too and all new hardware. Truck is not nor has never been in a salty environment but the bolts are being cut off by torch. There is just no other way! I am thinking of cutting my own wood as I have all the necessary tools, rather than buying a wood kit. The 16 Ga piece is something I have not thought of either so I will look into adapting that idea into the rebuild. The idea I am have is really for those who like to have pretty wood beds for show but still retain some functionality. My idea... ![]() I have bought some Trex (TM) planks that are the right size. Trex is a great product because it will last for decades (or centuries!), comes in many colors and grain styles. It is ALOT more expensive than hardwoods but also harder than hardwoods and is tremendously more resistant to scuffing, denting and gouging. All this is great but the best part about using Trex is that I don't have to sand, stain and poly for days or even weeks. Just cut, plane, router and install. I will give it a go and see how it all turns out. My truck will be the 'Guinea Pig' if you will. Once completed, I'll post some pitures. Since I am still in Iraq till October, I won't be able to post pics till then. Again, thanks for the idea. Any and all input is welcome! God Bless!
![]() Join Date: Jun 2010
Ole Greenie,,
Did you ever finish installing the trex wood in your bed?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. Last edited by FL71C10; 04-25-2011 at 09:17 AM. |
Never tried it on a truck bed wood floor but if you submerse new wood in clear glycol (like clear anti freeze-color is added) and heat it up while soaking, it will displace the water and prevent it from rotting. glycol never evaporates and will force all the water out. not sure about the finish coats and how it would react
#6 | |
If you plan on trying out the Trex boardsa new diamond or HD carbide bit is needed to router the grooves in the wood. I went through an old one I had and needed to buy a new bit which did a much better job. Heck that old bit was probably 15 years old so I needed a new one anyway. Trex is some pretty tough stuff and about twice as heavy as oak.
#7 | |
Never heard of Trex but will look in to it. Be interested in how it turms out |
I was talking to a customer on the phone and you posted pics. Looks good for somebody wanting a durable floor w/o much maintenance
#9 | |
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
so easy a caveman can do it...
![]() Join Date: May 2006
That looks great! Good job on that
#11 | |
http://www.trex.com/plan/products/tr...iles/index.htm They are considered trim or railing boards.
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 Last edited by Ole Greenie; 04-25-2011 at 11:38 AM. |
I am curious how it will handle the temperature changes. My neighbor used it on his deck. It does expand and contract with temp changes - almost as much as regular wood. Looks good though, and should outlast the rest of the truck.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
I've had it on there for a few months now and really haven't noticed any expansion issues with the composite decking. You are right about it lasting. It should last quite a while...which is one of the benefits! Thanks!
Thanks Mike. Every Soldier, Marine, Sailor and Airman likes the appreciation shown as a consequence of their service. I am priviledged to don this uniform and serve. I could always make more $ but there really is no comparison or substitute or anything more honorable.
#15 |
i replaced the wood in my bed in one weekend. hardest part was getting the old bolts out. I went with 30 year old Walnut for the look but according to my grandfather (he cut down the walnut tree my boards came from in 1980 lol) that ill never hurt it just scratch the finish! id go with real wood
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
