Old 08-16-2008, 11:45 PM   #151
jasonb72
PorterBuilt Man Crush
Re: Dropmember Rear 63-72 Spy Pic
asd
The 72 will live again
jasonb72 is offline   Reply With Quote
Old 10-21-2008, 03:03 AM   #152
jwcardy
just wondering why this thread has been dead for 2months...any updates on these kits nate?
-wes
jwcardy is offline   Reply With Quote
Old 10-21-2008, 07:09 AM   #153
Rokcrln
Rokcrln's Avatar
Nate~ With this set up how wide of a tire can you fit?
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-21-2008, 07:48 PM   #154
toocrazy
toocrazy's Avatar
Smile Re: Dropmember Rear 63-72 Spy Pic
-wes
I was wondering the same. It sure would be nice to see some pics of this kit installed
toocrazy is offline   Reply With Quote
Old 10-22-2008, 02:03 AM   #155
PBFAB.COM
PBFAB.COM's Avatar
I have sold quite a few of them.... maybe I better get some good pics up! Give me a couple days.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-22-2008, 09:07 AM   #156
SCOTI
SCOTI's Avatar
I have some from n2billet but don't want to post w/o permission.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-22-2008, 02:31 PM   #157
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I'm just finishing mine up. I only need to weld in my axle pads and I'm done.
http://67-72chevytrucks.com/vboard/s...28#post2930828
I'll try to get the pics with the 4 link/ panhard bar finished up in the next day or so.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 03-10-2009, 09:36 AM   #158
69Rob
69Rob's Avatar
so is there a price for just the notch?
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 04-30-2009, 10:08 PM   #159
gringoloco
A guy with a truck
gringoloco's Avatar
Do the link mounts align using the leaf hanger holes? Would this work on say, I dunno, a 4wd Blazer...?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-30-2009, 11:36 PM   #160
gringoloco
A guy with a truck
gringoloco's Avatar
I realized my post was a bit vague. I was speaking of the four-link. My Blazer is already step notched. If the brackets locate off the forward spring hanger holes, then it should align perfectly, since the Blazers and trucks share rear spring dimensions.
-Chris
Old 05-01-2009, 12:50 AM   #161
PBFAB.COM
PBFAB.COM's Avatar
Yes, they do bolt directly into the spring hanger bolts.
The only thing I would need to change is the angle of the forward mounting tabs (they sit at about a 4 degree angle due to the frame taper on the 2WD). Since the 4WD is a straight rail design, I would just need to eliminate the angle on the mount. It's a pretty simple change for me to make. If you are interested, I would just mod a bracket and send it out so you could test fit and verify.
Not sure if you would have to modify your floor for front upper bar clearance.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 06-30-2010, 08:35 PM   #162
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Well guys, I have emailed Nate and posted elsewhere but I figured I'd give you something semi-interesting to discuss.
Goal is to lay out a 62 LWB with a 63+ frame on air. Front will be the complete PB setup.
Options are
Rear drop setup using PBs Trailing arm "kit"(all PB parts like notch etc...)
Rear drop setup using PBs 4 link kit
I would automatically assume the 4 link is better but I have been wrong before. Will be a daily driver including the ND winters(focus on the suspension, not the winter affecting air ride) so any "extra" ground clearance is a plus. Big wheels are on the list of to do, I figure about 29" tire diameter. Most everything I have figured out so stick with the rear suspension differences. Thanks a ton guys!
What would you do?
Ghostwhite is offline   Reply With Quote
Old 06-30-2010, 10:36 PM   #163
SCOTI
SCOTI's Avatar
Options are
What would you do?
How wide of a rear tire are you planning? Both will put you on the ground w/PB's 4-bar set-up allowing up to 10" wide rear wheels & appropriate width tires. PB's T/A set-up allows for a little more (up to 12" wide wheels/tires).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-30-2010, 10:40 PM   #164
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Rim will be 10 inch wide or less
Old 07-01-2010, 11:43 AM   #165
Impalapawpaw
Impalapawpaw's Avatar
Check out my build under MY First Dimein the 60-66 build .It is a 65 lwb with porters kit all the way around.Any question i will help out were I can .Good luck
Impalapawpaw is offline   Reply With Quote
Old 07-01-2010, 11:48 AM   #166
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
I have been following yours from the start, love it. Yours and a few others have been my main inspiration.
I guess my main question is, suspension performance, which is better? Price wise they are close enough for my budget.
Old 07-01-2010, 11:58 AM   #167
Impalapawpaw
OK GOT ya.I hope to have mine on the road soon.But i went with what I did because i started something and the trailing arms fit what i stared.I would have loved the 4 link but had already started.I have heard that the 4 link rides great .Havent heard much on the trailing arms but I will but a review up when i get it on the road.
Old 07-01-2010, 12:04 PM   #168
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Both setups are legit thats for sure, I had already planned on the T arm setup but now that I have more time and budget, makes me wanna be sure of which I want. I know the 4 link has the advantage of sides but that alone is not enough of an advantage for me
Old 07-01-2010, 02:43 PM   #169
SCOTI
SCOTI's Avatar
Factory truck arms ride great w/bags as well.... PB's set-up won't ride worse.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-05-2010, 04:54 PM   #170
lowdownstar
big guy
lowdownstar's Avatar
hey scoti has any one confirmed that a 12" wide wheel will fit with the trailing arm setup yet? I have this setup on my 69 and the numbers don't look good. I wish i had a couple of wheels so i could see for sure with different back spacing. It is going to be close....
lowdownstar is offline   Reply With Quote
Old 07-05-2010, 05:26 PM   #171
SCOTI
SCOTI's Avatar
Mr. PB said 12" wide wheels would fit. Verify w/him....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-05-2010, 07:29 PM   #172
lowdownstar
big guy
I did try and confirm it with nathan but he couldn't say for sure. I didn't mean to upset anyone, the cost of wheels is way to high to mess up and i didn't want to wait. I guess i will be waitting till i can check for myself.
Thanks Ray
Old 07-06-2010, 02:09 AM   #173
PBFAB.COM
PBFAB.COM's Avatar
I did try and confirm it with nathan but he couldn't say for sure. I didn't mean to upset anyone, the cost of wheels is why to high to mess up and i didn't want to wait. I guess i will be waitting till i can check for myself.
Thanks Ray
I don't think anybody is upset. There is room for a 12" wide wheel, but I didn't have an offset to give (I have not yet installed a 12" wide wheel with this set-up), and suggested mock-up and measurement on your end. The last thing any of us want is a custom wheel that doesn't fit right. I will have some good mock up pics and measurements of a 20x10 with a 5.5" backspacing and a 67-69 rear-end here shortly. I will offer all the input and advice that I can... but the backspacing and measurement confirmation will be the end users ultimate responsibility.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-06-2010, 06:57 AM   #174
lowdownstar
big guy
I understand it's up to me nathan to make sure it's going to fit, i was just asking if anyone has done it yet to confirm, because when i had my setup together, (no bed) there was very little room for a 12 wheel. So your 100% right i need to mock it up for myself, but i also need the bed installed to do that right. For me it's aways nice to know that some one else has come up with the same numbers so i can feel better about what i found out. I made up a measuring stick and the wheel guys told me a 12" wheel is 13" across with out having one to measure i am not 100% sure of that. if they are, i had only like 3/4" of an inch before i hit the bag mounts. that didn't give me a good feeling they would fit. I am sorry for being a pain in the butt to everyone but i know you guys know a hell of lot more then me. Plus i am pour and don't have the money to screw up! I just didn't want to wait because the wheels take 4-6 weeks to come in, and the summer will be over before i can get it on the ground. that will make two years with out driving it and i am already in the dog house. thanks Ray
Old 07-06-2010, 10:35 AM   #175
SCOTI
SCOTI's Avatar
A 12" wheel does = 13" lip to lip as the tire bead needs approx .500" to seat.
As for calculating tire sidewall 'bulge', it can be done using other possible combos to get a visual 'feel' for how much room is necessary (a 315mm tire on a 12" wide wheel would have 'bulge' comparable to a 265mm tire on a 10" wheel etc....).
Ray, have you considered a 20 (or 22) x11"?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
