#1526 |
Senior Enthusiast
Re: What did you do to your truck today?
I'm not as young as I use to be, took me 3-1/2 hours to change out a leaking power steering pump. Glad that's over with.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#1527 |
hey i have got some seats like those for my truck but mine came out of a newer model chevy truck and are cloth but they are better than what is in there right now.
#1528 | |
60-66 Nut
That's great Vern, I'm stoked for ya.
#1529 |
60-66 Nut
That looks good. I agree that a couple inches in the front would be even better.
#1530 |
Been busy, over the past 4-5 days. Driving down the street the oil psi gauge sprung a leak and shot hot oil all over my legs and hands. The PO had over torqued the fitting and ruined it so I had to replace the gauge. I installed this triple setup instead. Still fresh back from the powdercoater I finished up installing the grill, park lights, rear, and backup light bezels. Yes
. those are step side back up lights. Still had troubles with the front turn signals so I scored a headlight switch and a pair of fleetside backup light sockets and glass lenses from the junk yard. Got all the electrical issues fixed and in working order. Also added a jumper wire so my front parklights are now running lights as well as turn signals. SWEET!
The price of cool aint cheap. |
#1531 |
I taped up, prepped and spray painted the outside frame around the vent window glass on the driver side... and painted the exterior side of the vent window assembly as well.
Tomorrow, the fun part... putting it back together. aggh. -W |
#1532 |
lets see I tore the pillar out and the rocker panel and bgan to fit the repo products in that I got from Clkassic parts, the fit is real nice. Has anybody done this before if pls post pics or send them to cal2indy@comcast.net Thanks jeff in Indy
#1533 |
![]() Join Date: Sep 2006
I put one tranny cooler line in becuase I forgot my double flaring tool. I also started it up again. I also set one of the exaust pipes I had under it and it is way off seeing it came out of my short bed. I will just build new ones. I also put the hood back on with the help of my Irish buddy.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#1534 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Did some cleaning in the engine Bay.
Little painting too.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#1535 |
Senior Enthusiast
Fabricated a panel to fit between the splash pans for mounting backup lights next to the license plate. Tuesday Ill take it to the local sheet metal shop and have them fold the edges in a brake.
I think it might actually look better than having the tank show from the rear as seen here: ![]() Heres the panel with and without the lamps: ![]() ![]() And here is where the lights will reside once the panel is completed: ![]() |
#1536 |
![]() Join Date: Nov 2007
Man, I like that idea MB. Thanks for sharing. I have been trying to think of a good way to mount backups without cutting holes in the bed sides.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#1537 |
Fire in the hole today!!
Well, sort of. Engine cranks but does not run. Shucks. TR
#1538 | |
Where did you purchase your repair panels from? How well are they fitting? Thanks |
#1539 |
Sunburst C10!!!
any more info on your aircleaner setup?
Gage 1967 C10 Shortbed Stepside |
#1540 |
I got all my panels from Classic industries in Kansas and the fit was awesome I did the pillars and the full Rockers so far give them a call they are great to deal with Jeff in Indy
#1541 | |
I do need to get one for the bottom of the door, and mabye the lower door skin anyone tried LMC (i think that's it) patch pannels, if so how do they fit.
My Build thread http://www.67-72chevytrucks.com/vboa...d.php?t=408574 |
#1542 |
OK today she cranked up!! (air in the fuel rail before??)
Will try to drive her tomorrow. JGH, Been busy getting the truck in running condition. I will post air cleaner thread soon. TR
#1543 |
Watched it rain alot and then sanded my grill support piece and ran the 1/2" front airline to behind the cab and cycled the bags a few times and checked for leaks.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#1544 |
i put my new carpet in sunday and messed with the motor a little also thought about swappin the externaly regulated alt for an internal
66 chevy lwb 355/400 |
#1545 |
Put the brightwork on the front of the K10...
#1546 |
One day...
Looks good Tony, nice and clean
#1547 |
Senior Enthusiast
Very impressive - as expected! Really like the white border and the bumper guards, makes it look authentic.
#1548 |
I`m going to have to cut the exhaust as they run over the axle inbetwen the panhard bar bracket and frame, I `m like a quarter of an inch from the exhaust now that is lower, any body trim rubber their stops in the rear, that might have to be done as well.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#1549 |
looks good rich!
#1550 |
Nice setup!
