Old 07-01-2010, 11:21 PM   #1
GMC Guy
GMC Guy's Avatar
fuel pump advice
i'm looking to replace my fuel pump while i have my front clip off (might as well).
right now i have a standard AC delco pump with two rubber lines and one hard line up to the carb. i want to put an Edelbrock preformer pump on since it puts out a lower psi. this way i won't need a fuel pressure regulator for my edelbrock 1406 carb. butttt....the edelbrock pump has one inlet and one outlet...how can i make this work? thoughts?
http://www.summitracing.com/parts/EDL-1721/
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 07-01-2010, 11:29 PM   #2
jrcaprai
Re: fuel pump advice
So are you saying how can you make it work with "with the two rubber lines" ???
jrcaprai is offline   Reply With Quote
Old 07-01-2010, 11:39 PM   #3
GMC Guy
GMC Guy's Avatar
nah, the my stock style pump has what seem to be two inlets, and one outlet. the edelbrock has one inlet and one outlet. how can i make it work?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 07-01-2010, 11:44 PM   #4
jrcaprai
Soooo, do you have dual fuel tanks? I am wondering if you have the 2 lines, one coming from each tank???
Old 07-01-2010, 11:48 PM   #5
GMC Guy
GMC Guy's Avatar
i do have dual tanks, so maybe it is one front each tank? i'm not sure, i'll have to go trace them back
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 07-02-2010, 12:10 AM   #6
jrcaprai
If it is, just get a Tee fitting and you're golden...
Old 07-02-2010, 08:28 AM   #7
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
The larger of the two is the feed line and the smaller is a return line. The two port (in and out) pump will work. Just block off the return line.
Mike
Mr.Chevy4x4 is offline   Reply With Quote
Old 07-02-2010, 09:32 AM   #8
cableguy0
Yup the smaller hose on the inlet side of the pump is just a return. just plug the line and call it good. The bigger 3/8's line is the fuel feed.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-02-2010, 12:23 PM   #9
GMC Guy
GMC Guy's Avatar
thanks guys
Greg
1974 GMC
L33 5.3/4l65e
.................__
