Old 07-02-2010, 08:39 PM   #1
chris91
lower control arm interchange
I need lower control arm bushings. 1964 c10 1/2 ton
Is a lower control arm from an 84 c10 a straight drop in, or will I have to change the upper too.
chris91 is offline   Reply With Quote
Old 07-03-2010, 02:08 AM   #2
Captainfab
60-66 Nut
Re: lower control arm interchange
The '84 control arms have rubber bushings versus the steel bushings on the '64. I prefer the later model rubber bushings myself. The '84 arms will bolt up, but i would recommend drilling out the U-bolt holes and using the larger '84 U-bolts. I would also just go ahead and change the uppers for the '84 arms while you're at it
Old 07-03-2010, 06:34 AM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
I think the ball joints differ as well
Heck, may as well do the disc brake conversion too,lol
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-03-2010, 03:36 PM   #4
raycow
Most people do the control arm swap as part of a disc brake conversion. If you want to keep your stock spindles you will need to replace the ball joints with the 63-70 type. Disc brake ball joints have a larger diameter stem (where they fit into the spindles) than the ones for drum brakes.
Ray
raycow is offline   Reply With Quote
