#601 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
ctrow, it was nice meeting you and your dad too..
little progress to report, been working on the hood shocks...fabbed up a lower mount that uses the 2 outboard bolts for the PB hood hinges, then welded a extension piece on the hood hinge arm... it wokred out well, now since i have the driver side made (more like the geomety figured out..) the pass side should go by alot quicker... ![]() ![]() ![]() |
#602 |
lookin good!
R.I.P. Killer 71 10/26/07 |
#603 |
Under Construction
looking good Don!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#604 |
Tot Roddin'
Really coming together... the fab work is phenominal!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#605 |
![]() Join Date: Nov 2003
I like the idea of running the fuses out of the side cowl, wiring is going to look very clean.
I was thinking about upgrading my wiper system to a newer model vehicle that is sealed, so you no longer need that wiper cowl drainage system. I was going to start hitting some junkyards and matching windshield sizes and see what I could come up with. Full size BMWs and Mercedes have a very nice structural wiper system that would probably require some minor fabrication...that is if the windshield sizes were similar.
Project Burro Viejo: http://67-72chevytrucks.com/vboard/s....php?p=3778216 |
#606 |
got the hood hinges made and installed, was going to 'hide' them in the wiper cowl area and use some bellcranks and rods to connect everything, but brother talked me into keeping it simple...and this way, it also isnt a maintance nightmare.....also brother and i got the bed installed (the body lines dont line up, due to the bed wood not being installed) but you get the idea of how it"ll look with 22s on there....also threw the grille on there as well...
#607 |
VA72C10
![]() Join Date: Mar 2008
Nice progress. Hinges came out cool. Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#608 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn she is really comming along..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#609 |
67cheby
![]() Join Date: Sep 2008
i have kept up with your post from the start and never realized you are from Tulsa, i would love to meet you and check out your truck
#610 |
Tot Roddin'
Holy freakin' cow... that looks good.
#611 |
![]() Join Date: Aug 2005
Love the hood section (and the rest too)!
#612 |
wow that looks bada$$ man. If you would could you "pm" me the price for the brake system, would love to get it for truck....someday.
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
#613 |
how much did this filler panel cost?
#614 |
5-600$ i believe!
#615 |
Junior Member
I tried to find where the filler panel was bought. But no luck. Where did yo uget it. I love the look.
70 chev c-10 long bed (prepping for second go round and short bed) ![]() |
#616 | ||
#617 |
I love the strut setup with the pb hinges. I'm doing that to mine. Where did you get the struts?
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
#618 |
67cheby
care to share the dimensions or the pattern for your hood strut pieces and part number for struts ??? it could sure help alot of us
#619 |
Still Learning
Thought for a minute there was an update.
#620 |
![]() Join Date: Sep 2007
Damn. Amazing build!
#621 |
where the updates,and is this all you do for a livin or you got another job,damn u got sum mad skills with that metal work,nice build and look forward to the rest.
#622 |
Kvn1011
I agree! Awesome build!
Posted via Mobile Device |
#623 |
So Many Ideas, So Little Money
Yea we have been waiting patiently....
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
#624 | |
http://www.67-72chevytrucks.com/vboa...d.php?t=405465 out, before i jump on hulk again...it'll be about 2 more weeks (porterbuilt stlye ![]() Last edited by 68 short step; 09-12-2010 at 08:46 PM. |
#625 |
ok, im getting back on hulk, blue-ray is bought wrapped up....so finished up some loose ends on the front sheetmetal...the sheetmetal was just cleckod in place, so i brought the holes up to size, and wleded nuts on where needed....also made a cosmetic peice that connects the inner fenders and hides the front most crossmember, and it also makes the engine 'pop' more, due to it hugging the front of the engine and accesories...i made this piece removable from the top, due to maintance (IE.. radiator hose replacement) here is the process of all that, and some pics of everything installed...
