Old 07-04-2010, 01:38 PM   #1
'65Burb
'65 front clip removal
I'm new and have a '65 Suburban. I want to first remove all the front sheet metal to detail the engine and firewall. I've noted some pics of guys removing the fenders and grill as a unit. Is that the way to go? What about the hood? Should I drill some 1/8" alignment holes to help in re-alignment when the hood goes back on? Any tips folks have for this sort of job will be appreciated. Thanks in advance. Lou
'65Burb is offline   Reply With Quote
Old 07-04-2010, 03:34 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: '65 front clip removal
Removing the front clip is easiest. You will need help of course unless you have an engine hoist. Take the hood off. If you are not going to spray the hinges you can just use something to mark the hood. I usually just put it back where the bolt marks are and it usually works pretty good, other then that it really isn't that hard to line up. Here is a picture of how I put the front clip back on by myself.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-04-2010, 06:16 PM   #3
'65Burb
Great, thanks for the info.
Old 07-04-2010, 11:33 PM   #4
Captainfab
60-66 Nut
There are basically 7 major bolts per side that will need to be removed. There are 2 behind the hood hinge that bolt the inner fender to the firewall. Then there is one at the inner fender above the frame back against the cab. If your truck has the cover that ties the inner fender together where the steering column shaft goes thru, that will need to be removed. There would be an additional 4 or 5 bolts there. Then there is a bolt at the bottom rear of the fender. There are two more bolts at the top of the fender, that are behind the fender extensions. There is also a little splash shield there that if removed makes removal a little easier......two sheetmetal screws there. Then there is the bolt that attaches the radiator support to the frame mount. Of course the bumper will need to be removed as well.
Old 07-05-2010, 01:58 AM   #5
DPowers
One foot in front of the other
DPowers's Avatar
Welcome to the site.
DPowers is offline   Reply With Quote
Old 07-05-2010, 10:02 AM   #6
'65Burb
Thanks again and glad to be here. Like I said, I want to detail the firewall and paint it what I plan to be the body color. Another big factor in this is that I have the deluxe heater and air package. I plan on restoring all of that and using it with the new style Sanyo (sp?) with Alan Grove mounts. Looks to me like some GM engineer went overboard designing that A/C unit with all the internal switches and controls. Is there an article out there on simplifying all of that with this sort of upgrade? I might should start a new thread on this subject.
Old 07-05-2010, 11:09 AM   #7
Chevy Fleetside
I went a bit overboard on the firewall on my 65 though.
Old 07-05-2010, 04:44 PM   #8
'65Burb
That's gorgeous!
Old 02-27-2013, 03:19 PM   #9
Blue_Aura
Blue_Aura's Avatar
Great info! I was looking for this and shouldn't be surprised that Captain would be the one providing it! Thanks to Capt. and everyone here, I am learning a lot.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline   Reply With Quote
Old 02-27-2013, 03:23 PM   #10
1963c-10
1963c-10's Avatar
No such thing as overboard is there....haha.
1964 Short bed trailer
Old 02-27-2013, 06:54 PM   #11
BHSM
BHSM's Avatar
Thanks Captainfab, This place is great, especially for newbs like me.
BHSM is offline   Reply With Quote
Old 02-27-2013, 07:35 PM   #12
Chevy Fleetside
Now
Old 02-27-2013, 08:03 PM   #13
Blue_Aura
Blue_Aura's Avatar
Originally Posted by Chevy Fleetside View Post
Now
I've said it before, I'll say it again... beautiful truck!! Still hoping to see it one day in SF (since I work there).
Current Vehicles:
Some Past Projects:
Old 02-27-2013, 08:36 PM   #14
Chevy Fleetside
bring your coveralls and you can help me work on it..
Old 02-27-2013, 08:51 PM   #15
Blue_Aura
Blue_Aura's Avatar
Coveralls? That truck is spotless! Oh, coveralls to PROTECT it from scratches, lol. What all do you have left to do to it? Pretty soon, I won't have my truck to work on, so I might just come over and help you. Your truck looks like the same color as mine, so I'll just pretend its mine for a few hours. ha ha.
Current Vehicles:
Some Past Projects:
Old 02-28-2013, 11:46 AM   #16
Chevy Fleetside
I have alot of liittle things to do. untill I get to the bed. OH yeah. I have another truck at the shop that needs to be taken apart. hahahhaa Acually 1 and a half
