Old 07-04-2010, 02:54 PM   #1
roofingbloke
Whats wrong ??
Whats wrong whith my wheel camber ?
63 c10, 2" drop spindles and lowerd coils, (soon to go on air bags) power steering.
When on full lock the wheel is leaving black marks on the tarmack,
See pictures.
roofingbloke is offline   Reply With Quote
Old 07-04-2010, 06:00 PM   #2
LONGHAIR
Re: Whats wrong ??
Have you had it aligned since installing the lowering parts? I would start with that, if the caster is off to far toward the positive, you get what is known as "camber gain". Try to get it back to the correct specs before trying to diagnose a problem.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 07-04-2010, 06:41 PM   #3
blazer2007
Re: Whats wrong ??
wouldn,t that be tie rod too far out,they tell you to bring it in so far on the intructions so as to get to alignment shop
blazer2007 is offline   Reply With Quote
Old 07-05-2010, 07:45 AM   #4
roofingbloke
Re: Whats wrong ??
The truck already had the drop spindles so im not sure about what was done,
Old 07-05-2010, 09:21 AM   #5
cdowns
cdowns's Avatar
Re: Whats wrong ??
lowered springs require the top control arm to b shimmed out// a good alignment shop should b able to correct
in some cases i've heard off needing longer mounting bolts and spacers for control arms r needed
Old 07-05-2010, 10:00 AM   #6
54Caddy
GM Addicted
54Caddy's Avatar
Re: Whats wrong ??
Longer bolts might come into the case depending on the amount of drop of the coils. My truck isnt set perfect either i need longer bolts. Ill handle that problem once i bag it so no biggy. Take your truck to a good alignment shop and they should be able to figure something out for you
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 07-05-2010, 12:23 PM   #7
kev2809
low n' slo
kev2809's Avatar
Re: Whats wrong ??
have you changed out any of the suspension up front (tie rods, ball joints, etc..)? be prepared for them to tell you that you need to before they can align it. it never fails with me...
nice truck by the way..
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-06-2010, 05:53 AM   #8
roofingbloke
Re: Whats wrong ??
Will have a good look at it today to see if i have any bolt thread left.
Thanks guys.
Old 07-07-2010, 01:26 AM   #9
roofingbloke
Re: Whats wrong ??
I have a good half inch of thred left>
Old 07-07-2010, 10:38 AM   #10
DKN
Active Member
Re: Whats wrong ??
The black marks on the ground at full steering lock is a resault of the ackermann angle. You can not change this. Each front tire needs to be steered slightly different to have neutral ackermann. This is because as you turn the inside tires is at a smaller turning radius than the outside tires. This part of the suspension also affects the toe angle. To get good high speed driving stabality you may have an ackermann angle that causes the front tires to "scrub" when at full steer.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 07-07-2010, 05:19 PM   #11
roofingbloke
Re: Whats wrong ??
Took a fiew pics with wheel off, looks stock to me, 6mm spacers and 10mm of bolt thread left.
Se pics.
Old 07-07-2010, 06:49 PM   #12
LONGHAIR
Re: Whats wrong ??
Yeah, what he said^^^
Old 07-08-2010, 07:10 AM   #13
63sbssbbw
UCA63
63sbssbbw's Avatar
Re: Whats wrong ??
I don't think I've ever seen so few shims in an uca
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 07-08-2010, 10:32 AM   #14
DKN
Active Member
Re: Whats wrong ??
Camber will not cause the tires to squeal, scrub, or leave black marks on the road. A motorcycle at regular speed gets all of its turning thrust from camber thrust. A motorcycle can operate at up to 60degrees of camber. Old VW, Porsche, and Corvair used swing axle rear suspension with very large amounts of camber change positive and negative. I have measured Ford I-Beam suspensions as far as 11 degrees negative camber at full compression.
If you are worried about the tires scrubing at full steering angle I would look at the toe measurement. If this toe angle is wrong because of the Ackermann then there is nothing to adjust. Toe in or toe out will definitely cause the tires to scrub, even a few degrees of toe can cause a problem.
My 2 cents, Danny Nix
CPP
Old 07-09-2010, 02:26 PM   #15
roofingbloke
Re: Whats wrong ??
Anyone got any pictures of a well set up front end with spacers in situation,
