Old 07-06-2010, 10:05 PM   #1
jack straw
jack straw's Avatar
Please Help! Need suggestions for suspension drop. 77 short box
Im kinda stuck on what to do for a suspension drop. Im looking to do a 3front 4 rear drop or something in that range. Im not sure what im gonna end up running for wheels either 15's with wider tires or go 22s. heres some questions i have any help would be appreciated.
Rear: Im thinking flip kit. is it necessary to install the c notch in the rear?
Front : i dont know what to do for a 3 or 4 inch drop. Drop spindles, A arms, Springs?
jack straw is offline   Reply With Quote
Old 07-06-2010, 11:00 PM   #2
Justin36
Justin36's Avatar
Re: Please Help! Need suggestions for suspension drop. 77 short box
Hey, sharp truck... You dont have to do a c-notch in the back with a flip kit, you will have to cut your factory bump stops off.. And springs and spindles should do the trick in the front
Justin
Justin36 is offline   Reply With Quote
Old 07-06-2010, 11:13 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
My advice is do it once, and be done with it. With that said, I prefer 3" spindles up front as it gives the most drop with out affecting the ride. If you want more you can cut a half to one full coil from your stock spring. In the rear, flip it. You don't have to do a C-notch, but I would. If you ever need it, you will wish it were there.
As far as wheels go, my vote is 20's all around. Unless your going to bag it, 22's look to big.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-07-2010, 07:54 PM   #4
menace121978
menace121978's Avatar
X2 on everything Ken said!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
